I have a problem when index.php was auto clipped : some line( html and JavaScript ) at the end off index.php was clipped!
I have tried to upload It again more than 6 times , but within 12 hours, It was auto clipped again and my site lost It tail .
Now I have cut some white line in index.php, I hope It wont clip again, but this solution isn’t well, is It?
Sorry, but it’s quite hard to figure out where/what the problem may be.
Where do you find this clipping - does it occur only when you retrieve the ressource via HTTP?
Or has the file itself been truncated, when you access it via FTP?
[quote=„chrisb“]Sorry, but it’s quite hard to figure out where/what the problem may be.
The first address is only the FTP address, It wont work in http, I putted it for Support only. You can access my homepage at w3.n27.uni.cc (using FireFox3 is recommend, IE or other navigator might have some err in graphic or JavaScript or CSS).
I find this clipping in the php source file:
+The original length of index.php ( source code ) is 250 line.
+After the first clipped, the length was 205 line (the 205th line has clipped some last words).
+At the second clipped, the length is 196 line.
Luckily, I has just clipped the line contain credit, hit counter and google-analytics of my site. I cannot wait for the third cliping , I always rewrite the index.php before the third cliping happen .
And only the index.php was clipped. No files else are clipped .
So just to get this absolutely clear: The index.php file is already truncated on the FTP-server? When you log in via FTP and look at the directory listing, the file size is wrong? (Taking into account differences regarding line breaks between Windows/Unix systems.)
[quote=“chrisb”]So just to get this absolutely clear: The index.php file is already truncated on the FTP-server?
No, FTP sever is work-well
Yes, I was wrong, but only after some hours[/quote]
example:at 29 Sep 2009 14:56:16 +0200, Just after I have upload index.php, the filesize has right , and I could access thought http normally, all thing are right. But at 30 Sep 2009 2:56:16 +0200, the size of index.php has changed(smaller), It has clipped…
I wont overwrite index.php in 48 hours, and I will take some screenshort If you want.
And the file w3.n27.uni.cc/player/index.php was clipped, too…
[attachment=2]Image1.png[/attachment]
[attachment=1]Image2.png[/attachment]
[attachment=0]Image3.png[/attachment]
