[code]##
@version $Id: htaccess.txt 13415 2009-11-03 15:53:25Z ian $
@package Joomla
@copyright Copyright © 2005 - 2008 Open Source Matters. All rights reserved.
Joomla! is Free Software
READ THIS COMPLETELY IF YOU CHOOSE TO USE THIS FILE
The line just below this section: ‘Options +FollowSymLinks’ may cause problems
with some server configurations. It is required for use of mod_rewrite, but may already
be set by your server administrator in a way that dissallows changing it in
your .htaccess file. If using it causes your server to error out, comment it out (add # to
beginning of line), reload your site in your browser and test your sef url’s. If they work,
it has been set by your server administrator and you do not need it set here.
Can be commented out if causes errors, see notes above.
mod_rewrite in use
RewriteEngine On
########## Begin - Rewrite rules to block out some common exploits
If you experience problems on your site block out the operations listed below
This attempts to block the most common type of exploit attempts
to Joomla!
Deny access to extension xml files (uncomment out to activate)
#<Files ~ “.xml$”>
#Order allow,deny
#Deny from all
#Satisfy all
End of deny access to extension xml files
RewriteCond %{QUERY_STRING} mosConfig_[a-zA-Z_]{1,21}(=|%3D) [OR]
Block out any script trying to base64_encode crap to send via URL
RewriteCond %{QUERY_STRING} base64_encode.(.) [OR]
Block out any script that includes a tag in URL
RewriteCond %{QUERY_STRING} (<|%3C).script.(>|%3E) [NC,OR]
Block out any script trying to set a PHP GLOBALS variable via URL
RewriteCond %{QUERY_STRING} GLOBALS(=|[|%[0-9A-Z]{0,2}) [OR]
Block out any script trying to modify a _REQUEST variable via URL
RewriteCond %{QUERY_STRING} _REQUEST(=|[|%[0-9A-Z]{0,2})
Send all blocked request to homepage with 403 Forbidden error!
RewriteRule ^(.*)$ index.php [F,L]
########## End - Rewrite rules to block out some common exploits
Uncomment following line if your webserver’s URL
is not directly related to physical file paths.
Update Your Joomla! Directory (just / for root)
RewriteBase /
########## Begin - Joomla! core SEF Section
RewriteCond %{REQUEST_URI} !^/index.php
RewriteCond %{REQUEST_URI} (/|.php|.html|.htm|.feed|.pdf|.raw|/[^.])$ [NC]
RewriteRule (.) index.php
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L]
########## End - Joomla! core SEF Section
[/code]
so, dass ist meine .htaccess
Leider habe ich jetzt nicht so ganz verstanden, wo ich was ersetzten soll. Ich finde es aber sehr nett, dass hier in so kurzer Zeit sich so viele leute meinem problem annehmen.
