sorry ich bin total überfordert. Aus der “Anleitung” auf der Webseite werde ich nicht schlau.
Die RSS Datei sieht so aus:
[code]<?php
Question2Answer 1.4 © 2011, Gideon Greenspan
http://www.question2answer.org/
File: qa-include/qa-feed.php
Version: 1.4
Date: 2011-06-13 06:42:43 GMT
Description: Handles all requests to RSS feeds, first checking if they should be available
This program is free software; you can redistribute it and/or
modify it under the terms of the GNU General Public License
as published by the Free Software Foundation; either version 2
of the License, or (at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
More about this license: http://www.question2answer.org/license.php
if (!defined('QA_VERSION')) { // don't allow this page to be requested directly from browser
header('Location: ../');
exit;
@ini_set('display_errors', 0); // we don't want to show PHP errors to RSS readers
require_once QA_INCLUDE_DIR.'qa-app-options.php';
// Functions used within this file
function qa_feed_db_fail_handler($type, $errno=null, $error=null, $query=null)
Database failure handler function for RSS feeds - outputs HTTP and text errors
header('HTTP/1.1 500 Internal Server Error');
echo qa_lang_html('main/general_error');
exit;
function qa_feed_not_found()
Common function called when a non-existent feed is requested - outputs HTTP and text errors
header(‘HTTP/1.0 404 Not Found’);
echo qa_lang_html(‘misc/feed_not_found’);
exit;
function qa_feed_load_ifcategory($allkey, $catkey, $questionselectspec1=null, $questionselectspec2=null, $questionselectspec3=null, $questionselectspec4=null)
Common function to load appropriate set of questions for requested feed, check category exists, and set up page title
global $categoryslugs, $countslugs, $categories, $categoryid, $title, $questions;
@list($questions1, $questions2, $questions3, $questions4, $categories, $categoryid)=qa_db_select_with_pending(
$questionselectspec1,
$questionselectspec2,
$questionselectspec3,
$questionselectspec4,
$countslugs ? qa_db_category_nav_selectspec($categoryslugs, false) : null,
$countslugs ? qa_db_slugs_to_category_id_selectspec($categoryslugs) : null
if ($countslugs && !isset($categoryid))
qa_feed_not_found();
$questions=array_merge(
is_array($questions1) ? $questions1 : array(),
is_array($questions2) ? $questions2 : array(),
is_array($questions3) ? $questions3 : array(),
is_array($questions4) ? $questions4 : array()
if (isset($allkey) && isset($catkey))
$title=isset($categoryid) ? qa_lang_sub($catkey, $categories[$categoryid]['title']) : qa_lang($allkey);
// Connect to database and get the type of feed and category requested (in some cases these are overridden later)
qa_base_db_connect('qa_feed_db_fail_handler');
end($qa_request_lc_parts);
$lastkey=key($qa_request_lc_parts);
if (isset($lastkey)) {
$suffix=substr($qa_request_lc_parts[$lastkey], -4);
if (($suffix=='.rss') || ($suffix=='.xml'))
$qa_request_lc_parts[$lastkey]=substr($qa_request_lc_parts[$lastkey], 0, -4);
$feedtype=@$qa_request_lc_parts[1];
$feedparams=array_slice($qa_request_lc_parts, 2);
// Choose which option needs to be checked to determine if this feed can be requested, and stop if no matches
$feedoption=null;
$categoryslugs=$feedparams;
switch ($feedtype) {
case 'questions':
$feedoption='feed_for_questions';
break;
case 'unanswered':
$feedoption='feed_for_unanswered';
$categoryslugs=null;
break;
case 'answers':
case 'comments':
case 'activity':
$feedoption='feed_for_activity';
break;
case 'qa':
$feedoption='feed_for_qa';
break;
case 'tag':
if (strlen(@$feedparams[0])) {
$feedoption='feed_for_tag_qs';
break;
case 'search':
$feedoption='feed_for_search';
break;
$countslugs=@count($categoryslugs);
if (!isset($feedoption))
// Check that all the appropriate options are in place to allow this feed to be retrieved
if (!(
(qa_opt($feedoption)) &&
($countslugs ? (qa_using_categories() && qa_opt('feed_per_category')) : true)
// Retrieve the appropriate questions and other information for this feed
require_once QA_INCLUDE_DIR.'qa-db-selects.php';
$sitetitle=qa_opt('site_title');
$siteurl=qa_opt('site_url');
$full=qa_opt('feed_full_text');
$count=qa_opt('feed_number_items');
$showurllinks=qa_opt('show_url_links');
$linkrequest=$feedtype.($countslugs ? ('/'.implode('/', $categoryslugs)) : '');
$linkparams=null;
case 'questions':
qa_feed_load_ifcategory('main/recent_qs_title', 'main/recent_qs_in_x',
qa_db_qs_selectspec(null, 'created', 0, $categoryslugs, null, false, $full, $count)
break;
case 'unanswered':
qa_feed_load_ifcategory('main/unanswered_qs_title', 'main/unanswered_qs_in_x',
qa_db_unanswered_qs_selectspec(null, 0, null, false, $full, $count)
break;
case 'answers':
qa_feed_load_ifcategory('main/recent_as_title', 'main/recent_as_in_x',
qa_db_recent_a_qs_selectspec(null, 0, $categoryslugs, null, false, $full, $count)
break;
case 'comments':
qa_feed_load_ifcategory('main/recent_cs_title', 'main/recent_cs_in_x',
qa_db_recent_c_qs_selectspec(null, 0, $categoryslugs, null, false, $full, $count)
break;
case 'qa':
qa_feed_load_ifcategory('main/recent_qs_as_title', 'main/recent_qs_as_in_x',
qa_db_qs_selectspec(null, 'created', 0, $categoryslugs, null, false, $full, $count),
break;
case 'activity':
qa_feed_load_ifcategory('main/recent_activity_title', 'main/recent_activity_in_x',
qa_db_recent_a_qs_selectspec(null, 0, $categoryslugs, null, false, $full, $count),
qa_db_recent_c_qs_selectspec(null, 0, $categoryslugs, null, false, $full, $count),
qa_db_recent_edit_qs_selectspec(null, 0, $categoryslugs, null, true, $full, $count)
break;
case 'tag':
$tag=$feedparams[0];
qa_feed_load_ifcategory(null, null,
qa_db_tag_recent_qs_selectspec(null, $tag, 0, $full, $count)
$title=qa_lang_sub('main/questions_tagged_x', $tag);
$linkrequest='tag/'.$tag;
break;
case 'search':
require_once QA_INCLUDE_DIR.'qa-util-string.php';
$query=$feedparams[0];
$words=qa_string_to_words($query);
qa_db_search_posts_selectspec(null, $words, $words, $words, $words, trim($query), 0, $full, $count)
$title=qa_lang_sub('main/results_for_x', $query);
$linkrequest='search';
$linkparams=array('q' => $query);
break;
// Remove duplicate questions (perhaps referenced in an answer and a comment) and cut down to size
require_once QA_INCLUDE_DIR.'qa-app-format.php';
if ($feedtype!='search') // leave search results sorted by relevance
$questions=qa_any_sort_and_dedupe($questions);
$questions=array_slice($questions, 0, $count);
$blockwordspreg=qa_get_block_words_preg();
// Disconnect as quickly as possible to free up resources
qa_base_db_disconnect();
// Prepare the XML output
$lines=array();
$lines[]='<?xml version="1.0" encoding="UTF-8"?>';
$lines[]='<rss version="2.0">';
$lines[]='<channel>';
$lines[]='<title>'.qa_html($sitetitle.' - '.$title).'</title>';
$lines[]='<link>'.qa_path_html($linkrequest, $linkparams, $siteurl).'</link>';
$lines[]='<description>Powered by Question2Answer</description>';
foreach ($questions as $question) {
// Determine whether this is a question, answer or comment, and act accordingly
$options=array('blockwordspreg' => @$blockwordspreg, 'showurllinks' => $showurllinks);
$anchor=null;
if (isset($question['opostid'])) {
if ($question['obasetype']!='Q')
$anchor=qa_anchor($question['obasetype'], $question['opostid']);
$time=$question['otime'];
if ($full)
$htmlcontent=qa_viewer_html($question['ocontent'], $question['oformat'], $options);
} else {
$time=$question['created'];
if ($full)
$htmlcontent=qa_viewer_html($question['content'], $question['format'], $options);
switch (@$question['obasetype']) {
case 'A':
$titleprefix=@$question['oedited'] ? qa_lang('misc/feed_a_edited_prefix') : qa_lang('misc/feed_a_prefix');
break;
case 'C':
$titleprefix=@$question['oedited'] ? qa_lang('misc/feed_c_edited_prefix') : qa_lang('misc/feed_c_prefix');
break;
default:
$titleprefix=@$question['oedited'] ? qa_lang('misc/feed_edited_prefix') : '';
break;
if (isset($blockwordspreg))
$question['title']=qa_block_words_replace($question['title'], $blockwordspreg);
$urlhtml=qa_path_html(qa_q_request($question['postid'], $question['title']), null, $siteurl, null, $anchor);
// Build the inner XML structure for each item
$lines[]='<item>';
$lines[]='<title>'.qa_html($titleprefix.$question['title']).'</title>';
$lines[]='<link>'.$urlhtml.'</link>';
if ($full && isset($htmlcontent))
$lines[]='<description>'.qa_html($htmlcontent).'</description>'; // qa_html() a second time to put HTML code inside XML wrapper
if (isset($question['categoryname']))
$lines[]='<category>'.qa_html($question['categoryname']).'</category>';
$lines[]='<guid isPermaLink="true">'.$urlhtml.'</guid>';
$lines[]='<pubDate>'.qa_html(gmdate('r', $time)).'</pubDate>';
$lines[]='</item>';
$lines[]='</channel>';
$lines[]='</rss>';
// Output the XML - and we’re done!
header('Content-type: text/xml; charset=utf-8');
echo implode("\n", $lines);
Omit PHP closing tag to help avoid accidental output
*/[/code]
Wenn du Recht hast, Kerbi, müsste das ja wirklich schnell geschrieben sein. Es würde mir sehr helfen das einbinden zu können. Dass der Hersteller ein solches Modul nicht gleich mitliefert kapiere nicht.
