I can’t find where to put the CNAME in at godaddy.com. It seems they just updated the site, so the CNAME and total dns control option are no longer on the main screen. Is there a way to connect my site her without using a CNAME and just the regular nameserver name?
Nvm… I fixed my problems.
Good morning,
it’s great that you find a solution for your problem. Perhaps you may post how you fixed it so other users with the same problem get an impression what to do.
Kind regards
myPages
I didn’t know that you need to park your domain first before switching from regular nameservers to CNAME. I just parked it and then followed the godaddy directions and it worked.
