danke für deine antwort.
hier findet man das ergebnis (Demo 3): LINK
[code]// -------------------------------------------------------------------
// Virtual Pagination Script- By Dynamic Drive, available at: http://www.dynamicdrive.com
// Last updated: Nov 21st, 2008 to v2.0
// ** Adds ability to define multiple pagination DIVs (the secondary DIVs mirror primary DIV’s contents)
// ** Last viewed page persistence, so last viewed page can be remembered/ recalled within browser session.
// ** Improvements to instance.navigate() to select a page using an arbitrary link or inside another script.
// ** Ability to select a page using a URL parameter (ie: target.htm?virtualpiececlass=index).
// PUBLIC: virtualpaginate()
// Main Virtual Paginate Object function.
document.write(’’ //write out CSS for class “.hidepeice” that hides pieces of contents within pages
+’.hidepiece{display:none}\n’
+’@media print{.hidepiece{display:block !important;}}\n’
function virtualpaginate(config){ //config: {piececlass:, piececontainer:, pieces_per_page:, defaultpage:, persist}
this.piececlass=config.piececlass
var elementType=(typeof config.piececontainer==“undefined”)? “div” : config.piececontainer //The type of element used to divide up content into pieces. Defaults to "div"
this.pieces=virtualpaginate.collectElementbyClass(config.piececlass, elementType) //get total number of divs matching class name
//Set this.chunksize: 1 if “chunksize” param is undefined, “chunksize” if it’s less than total pieces available, or simply total pieces avail (show all)
this.chunksize=(typeof config.pieces_per_page==“undefined”)? 1 : (config.pieces_per_page>0 && config.pieces_per_page<this.pieces.length)? config.pieces_per_page : this.pieces.length
this.pagecount=Math.ceil(this.pieces.length/this.chunksize) //calculate number of “pages” needed to show the divs
this.paginatediv=[], this.flatviewlinks=[], this.cpspan=[], this.selectmenu=[]
this.persist=config.persist
var persistedpage=virtualpaginate.getCookie(“dd_”+this.piececlass) || 0
var urlselectedpage=virtualpaginate.urlparamselect(this.piececlass) //returns null or index from: mypage.htm?piececlass=index
this.currentpage=(typeof urlselectedpage==“number”)? urlselectedpage : ((this.persist)? persistedpage : config.defaultpage)
this.currentpage=(this.currentpage<this.pagecount)? parseInt(this.currentpage) : 0 //ensure currentpage is within range of available pages
this.showpage(this.currentpage) //Show selected page
// PUBLIC: navigate(keyword)- Calls this.showpage() based on parameter passed (0=page1, 1=page2 etc, “next”, “first”, or “last”)
virtualpaginate.prototype.navigate=function(keyword){
var prevlinkindex=this.currentpage //Get index of last clicked on page
if (keyword==“previous”)
this.currentpage=(this.currentpage>0)? this.currentpage-1 : (this.currentpage==0)? this.pagecount-1 : 0
else if (keyword==“next”)
this.currentpage=(this.currentpage<this.pagecount-1)? this.currentpage+1 : 0
else if (keyword==“first”)
this.currentpage=0
else if (keyword==“last”)
this.currentpage=this.pagecount-1 //last page number
else
this.currentpage=parseInt(keyword)
this.currentpage=(this.currentpage<this.pagecount)? this.currentpage : 0 //ensure pagenumber is within range of available pages
for (var p=0; p<this.paginatediv.length; p++){ //loop through all pagination DIVs
if (this.flatviewpresent)
this.flatviewlinks[p][prevlinkindex].className="" //“Unhighlight” previous page (before this.currentpage increments)
if (this.selectmenupresent)
this.selectmenu[p].selectedIndex=this.currentpage
this.flatviewlinks[p][this.currentpage].className=“selected” //“Highlight” current page
// PUBLIC: buildpagination()- Create pagination interface by calling one or more of the paginate_build_() functions
virtualpaginate.prototype.buildpagination=function(divids, optnavtext){
var divids=(typeof divids==“string”)? [divids] : divids //force divids to be an array of ids
var primarypaginatediv=divids.shift() //get first id within divids[]
var paginaterawHTML=document.getElementById(primarypaginatediv).innerHTML
this.paginate_build(primarypaginatediv, 0, optnavtext)
for (var i=0; i<divids.length; i++){
document.getElementById(divids[i]).innerHTML=paginaterawHTML
this.paginate_build(divids[i], i+1, optnavtext)
// PRIVATE utility functions
virtualpaginate.collectElementbyClass=function(classname, element){ //Returns an array containing DIVs with specified classname
if (document.querySelectorAll){
var pieces=document.querySelectorAll(element+"."+classname) //return pieces as HTMLCollection
else{
var classnameRE=new RegExp("(^|\s+)"+classname+"($|\s+)", “i”) //regular expression to screen for classname within element
var pieces=[]
var alltags=document.getElementsByTagName(element)
for (var i=0; i<alltags.length; i++){
if (typeof alltags[i].className==“string” && alltags[i].className.search(classnameRE)!=-1)
pieces[pieces.length]=alltags[i] //return pieces as array
return pieces
virtualpaginate.urlparamselect=function(vpclass){
var result=window.location.search.match(new RegExp(vpclass+"=(\d+)", “i”)) //check for “?piececlass=2” in URL
return (result==null)? null : parseInt(RegExp.$1) //returns null or index, where index (int) is the selected virtual page’s index
virtualpaginate.getCookie=function(Name){
var re=new RegExp(Name+"=[^;]+", “i”); //construct RE to search for target name/value pair
if (document.cookie.match(re)) //if cookie found
return document.cookie.match(re)[0].split("=")[1] //return its value
return null
virtualpaginate.setCookie=function(name, value){
document.cookie = name+"="+value
// PRIVATE: showpage(pagenumber)- Shows a page based on parameter passed (0=page1, 1=page2 etc)
virtualpaginate.prototype.showpage=function(pagenumber){
var totalitems=this.pieces.length //total number of broken up divs
var showstartindex=pagenumber*this.chunksize //array index of div to start showing per pagenumber setting
var showendindex=showstartindex+this.chunksize-1 //array index of div to stop showing after per pagenumber setting
for (var i=0; i<totalitems; i++){
if (i>=showstartindex && i<=showendindex)
this.pieces[i].style.display="block"
else
this.pieces[i].style.display=“none”
if (this.persist){ //if persistence enabled
virtualpaginate.setCookie(“dd_”+this.piececlass, this.currentpage)
if (this.cpspan.length>0){ //if <span class="paginateinfo> element is present, update it with the most current info (ie: Page 3/4)
for (var p=0; p<this.cpspan.length; p++)
this.cpspan[p].innerHTML=‘Page ‘+(this.currentpage+1)+’/’+this.pagecount
// PRIVATE: build() methods- Various methods to create pagination interfaces
// paginate_paginate_build()- Main build() paginate function
// paginate_output_flatview()- Accepts element and populates it with sequential pagination links
// paginate_paginate_build_flatview()- Parses the modified element and assigns click behavior to the pagination links
// paginate_build_selectmenu(paginatedropdown)- Accepts an empty SELECT element and turns it into pagination menu
// paginate_build_regularlinks(paginatelinks)- Accepts a collection of links and screens out/ creates pagination out of ones with specific “rel” attr
// paginate_build_cpinfo(cpspan)- Accepts element and displays current page info (ie: Page 1/4)
virtualpaginate.prototype.paginate_build=function(divid, divpos, optnavtext){
var instanceOfBox=this
var paginatediv=document.getElementById(divid)
if (this.chunksize==this.pieces.length){ //if user has set to display all pieces at once, no point in creating pagination div
paginatediv.style.display="none"
return
var paginationcode=paginatediv.innerHTML //Get user defined, “unprocessed” HTML within paginate div
if (paginatediv.getElementsByTagName(“select”).length>0) //if there’s a select menu in div
this.paginate_build_selectmenu(paginatediv.getElementsByTagName(“select”)[0], divpos, optnavtext)
if (paginatediv.getElementsByTagName(“a”).length>0) //if there are links defined in div
this.paginate_build_regularlinks(paginatediv.getElementsByTagName(“a”))
var allspans=paginatediv.getElementsByTagName(“span”) //Look for span tags within passed div
for (var i=0; i<allspans.length; i++){
if (allspans[i].className==“flatview”)
this.paginate_output_flatview(allspans[i], divpos, optnavtext)
else if (allspans[i].className==“paginateinfo”)
this.paginate_build_cpinfo(allspans[i], divpos)
this.paginatediv[divpos]=paginatediv
virtualpaginate.prototype.paginate_output_flatview=function(flatviewcontainer, divpos, anchortext){
var flatviewhtml=""
var anchortext=anchortext || new Array()
for (var i=0; i<this.pagecount; i++){
if (typeof anchortext[i]!=“undefined”) //if custom anchor text for this link exists
flatviewhtml+=’’+anchortext[i]+’ ’ //build pagination link using custom anchor text
else
flatviewhtml+=’’+(i+1)+’ ’ //build pagination link using auto incremented sequential number instead
flatviewcontainer.innerHTML=flatviewhtml
this.paginate_build_flatview(flatviewcontainer, divpos, anchortext)
virtualpaginate.prototype.paginate_build_flatview=function(flatviewcontainer, divpos, anchortext){
var flatviewhtml=""
this.flatviewlinks[divpos]=flatviewcontainer.getElementsByTagName(“a”)
for (var i=0; i<this.flatviewlinks[divpos].length; i++){
this.flatviewlinks[divpos][i].onclick=function(){
var prevlinkindex=instanceOfBox.currentpage //Get index of last clicked on flatview link
var curlinkindex=parseInt(this.getAttribute(“rel”))
instanceOfBox.navigate(curlinkindex)
return false
this.flatviewlinks[divpos][this.currentpage].className=“selected” //“Highlight” current flatview link
this.flatviewpresent=true //indicate flat view links are present
virtualpaginate.prototype.paginate_build_selectmenu=function(paginatedropdown, divpos, anchortext){
this.selectmenupresent=1
if (typeof anchortext[i]!=“undefined”) //if custom anchor text for this link exists, use anchor text as each OPTION’s text
paginatedropdown.options[i]=new Option(anchortext[i], i)
else //else, use auto incremented, sequential numbers
paginatedropdown.options[i]=new Option("Page “+(i+1)+” of "+this.pagecount, i)
paginatedropdown.selectedIndex=this.currentpage
setTimeout(function(){paginatedropdown.selectedIndex=instanceOfBox.currentpage}, 500) //refresh currently selected option (for IE’s sake)
paginatedropdown.onchange=function(){
instanceOfBox.navigate(this.selectedIndex)
this.selectmenu[divpos]=paginatedropdown
this.selectmenu[divpos].selectedIndex=this.currentpage //“Select” current page’s corresponding option
virtualpaginate.prototype.paginate_build_regularlinks=function(paginatelinks){
for (var i=0; i<paginatelinks.length; i++){
var currentpagerel=paginatelinks[i].getAttribute(“rel”)
if (currentpagerel==“previous” || currentpagerel==“next” || currentpagerel==“first” || currentpagerel==“last”){ //screen for these “rel” values
paginatelinks[i].onclick=function(){
instanceOfBox.navigate(this.getAttribute(“rel”))
return false
virtualpaginate.prototype.paginate_build_cpinfo=function(cpspan, divpos){
this.cpspan[divpos]=cpspan
cpspan.innerHTML=‘Page ‘+(this.currentpage+1)+’/’+this.pagecount
[/code]
und das gehört noch in die index.php
[code][/code]
