[quote]############################################
uncomment these lines for CGI mode
make sure to specify the correct cgi php binary file name
it might be /cgi-bin/php-cgi
Action php5-cgi /cgi-bin/php5-cgi
AddHandler php5-cgi .php
GoDaddy specific options
Options -MultiViews
you might also need to add this line to php.ini
cgi.fix_pathinfo = 1
if it still doesn’t work, rename php.ini to php5.ini
this line is specific for 1and1 hosting
#AddType x-mapp-php5 .php
#AddHandler x-mapp-php5 .php
default index file
DirectoryIndex index.php
adjust memory limit
php_value memory_limit 64M
php_value memory_limit 256M
php_value max_execution_time 18000
disable magic quotes for php request vars
php_flag magic_quotes_gpc off
disable automatic session start
before autoload was initialized
php_flag session.auto_start off
enable resulting html compression
#php_flag zlib.output_compression on
disable user agent verification to not break multiple image upload
php_flag suhosin.session.cryptua off
turn off compatibility with PHP4 when dealing with objects
php_flag zend.ze1_compatibility_mode Off
# disable POST processing to not break multiple image upload
SecFilterEngine Off
SecFilterScanPOST Off
enable apache served files compression
# Insert filter on all content
###SetOutputFilter DEFLATE
# Insert filter on selected content types only
#AddOutputFilterByType DEFLATE text/html text/plain text/xml text/css text/javascript
# Netscape 4.x has some problems...
#BrowserMatch ^Mozilla/4 gzip-only-text/html
# Netscape 4.06-4.08 have some more problems
#BrowserMatch ^Mozilla/4\.0[678] no-gzip
# MSIE masquerades as Netscape, but it is fine
#BrowserMatch \bMSIE !no-gzip !gzip-only-text/html
# Don't compress images
#SetEnvIfNoCase Request_URI \.(?:gif|jpe?g|png)$ no-gzip dont-vary
# Make sure proxies don't deliver the wrong content
#Header append Vary User-Agent env=!dont-vary
make HTTPS env vars available for CGI mode
SSLOptions StdEnvVars
enable rewrites
Options +FollowSymLinks
RewriteEngine on
you can put here your magento root folder
path relative to web root
#RewriteBase /magento/
uncomment next line to enable light API calls processing
RewriteRule ^api/([a-z][0-9a-z_]+)/?$ api.php?type=$1 [QSA,L]
rewrite API2 calls to api.php (by now it is REST only)
RewriteRule ^api/rest api.php?type=rest [QSA,L]
workaround for HTTP authorization
in CGI environment
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
TRACE and TRACK HTTP methods disabled to prevent XSS attacks
RewriteCond %{REQUEST_METHOD} ^TRAC[EK]
RewriteRule .* - [L,R=405]
redirect for mobile user agents
#RewriteCond %{REQUEST_URI} !^/mobiledirectoryhere/.*$
#RewriteCond %{HTTP_USER_AGENT} "android|blackberry|ipad|iphone|ipod|iemobile|opera mobile|palmos|webos|googlebot-mobile" [NC]
#RewriteRule ^(.*)$ /mobiledirectoryhere/ [L,R=302]
always send 404 on missing files in these folders
RewriteCond %{REQUEST_URI} !^/(media|skin|js)/
never rewrite for existing files, directories and links
RewriteCond %{REQUEST_FILENAME} !-l
rewrite everything else to index.php
RewriteRule .* index.php [L]
Prevent character encoding issues from server overrides
If you still have problems, use the second line instead
AddDefaultCharset Off
#AddDefaultCharset UTF-8
Add default Expires header
ExpiresDefault "access plus 1 year"
By default allow all access
Order allow,deny
Allow from all
Deny access to release notes to prevent disclosure of the installed Magento version
<Files RELEASE_NOTES.txt>
order allow,deny
deny from all
</Files>
If running in cluster environment, uncomment this
#FileETag none
Kannst du damit was anfangen? Den anderen Fehler habe ich gefunden, aber wäre schön wenn ich das mit der htaccess auch noch gebacken bekomme
Danke!
