FTP won't work
I can login to my FTP account but if i try to run command “DIR” or upload something then i get this message
I won’t open a connection to 0.0.0.0 (only to 78.46.34.147)
i’m sorry, this is a known bug, we should get rid of it within 24 hours, … perhaps another ftp-client will do, depending on the ftp/rfc-implementation …
I have tried Windows default FTP client, Filezilla, TotalCommander and a PHP based client, same problem :-/
crap :confused:
then time will have to heal that one, debugging ASAP
sorry, no solution was found yet since this issue seems to be more complex than expected - a workaround is to switch to passive mode, it works very well then.
What if passive mode won’t work either?
I get a “Password required” message, even I have typed it in.
Just try another FTP Client - e.g. Filezilla should work.
already tried a few still wouldn’t work.
i just created a new bplaced account and it works now so problem solved :smoke:
already removed the old one
thanks :slight_smile:
