My site is not working
IP 78.46.37.18
[quote=“afftamat”]My site is not working
IP 78.46.37.18[/quote]
karabulak.bplaced.net/ this is your site, it’s right? ? Your site working.
This IP adress “78.46.37.18” is from Server 3, by bplaced.net
[quote=“fishi”][quote=“afftamat”]My site is not working
I want to join the domain example.com, I am writing this IP-address in type A, but my site does not open
The Domain „example.com“ isn’t by you.
Perhaps you think a different domain?
[quote=„fishi“]The Domain „example.com“ isn’t by you.
Perhaps you think a different domain?[/quote]
„example.com“ it is for example ))
activate the domain @ your domainprovider and direct it to 78.46.37.18.
Then you go to the bplaced acp ( admin controll panel) and add the domain in the domains tab
then you need to wait for arround 3 hours till the domain is avaible worldwide
greetz Michi
I registered at everydns.com, I have a domain type example.cn and when I enter the IP and karabulak.bplaced.net, it appears Status: Your record is for the wrong domain
greetz Michi[/quote]
but this IP will not open my site
Thx 4 all. My site is working
Just wait
It should be purely a legal notice, at your side.
With the first name, name and address.
ru:
Подождите.
Она должна быть сугубо официальное уведомление, на вашей стороне.
Что имя, фамилию и адрес.
[size=55](Wegen der PN der er/sie mir geschickt hat.)[/size]
