.htaccess problem
Can someone tell me what is wrong with this code ?
i keep get an 500 internal server error whenever i use this
.htaccess
[code]Options -MultiViews +FollowSymlinks -Indexes
If mod_security is enabled, attempt to disable it.
- Note, this will work on the majority of hosts but on
MediaTemple, it is known to cause random Internal Server
errors. For MediaTemple, please remove the block below
# Turn off mod_security filtering. SecFilterEngine Off
# The below probably isn't needed, but better safe than sorry.
SecFilterScanPOST Off
MyBB “search engine friendly” URL rewrites
- Note, for these to work with MyBB please make sure you have
the setting enabled in the Admin CP and you have this file
named .htaccess
RewriteEngine on RewriteRule ^forum-([0-9]+)\.html$ forumdisplay.php?fid=$1 [L,QSA] RewriteRule ^forum-([0-9]+)-page-([0-9]+)\.html$ forumdisplay.php?fid=$1&page=$2 [L,QSA]
RewriteRule ^thread-([0-9]+)\.html$ showthread.php?tid=$1 [L,QSA]
RewriteRule ^thread-([0-9]+)-page-([0-9]+)\.html$ showthread.php?tid=$1&page=$2 [L,QSA]
RewriteRule ^thread-([0-9]+)-lastpost\.html$ showthread.php?tid=$1&action=lastpost [L,QSA]
RewriteRule ^thread-([0-9]+)-nextnewest\.html$ showthread.php?tid=$1&action=nextnewest [L,QSA]
RewriteRule ^thread-([0-9]+)-nextoldest\.html$ showthread.php?tid=$1&action=nextoldest [L,QSA]
RewriteRule ^thread-([0-9]+)-newpost\.html$ showthread.php?tid=$1&action=newpost [L,QSA]
RewriteRule ^thread-([0-9]+)-post-([0-9]+)\.html$ showthread.php?tid=$1&pid=$2 [L,QSA]
RewriteRule ^post-([0-9]+)\.html$ showthread.php?pid=$1 [L,QSA]
RewriteRule ^announcement-([0-9]+)\.html$ announcements.php?aid=$1 [L,QSA]
RewriteRule ^user-([0-9]+)\.html$ member.php?action=profile&uid=$1 [L,QSA]
RewriteRule ^calendar-([0-9]+)\.html$ calendar.php?calendar=$1 [L,QSA]
RewriteRule ^calendar-([0-9]+)-year-([0-9]+)\.html$ calendar.php?action=yearview&calendar=$1&year=$2 [L,QSA]
RewriteRule ^calendar-([0-9]+)-year-([0-9]+)-month-([0-9]+)\.html$ calendar.php?calendar=$1&year=$2&month=$3 [L,QSA]
RewriteRule ^calendar-([0-9]+)-year-([0-9]+)-month-([0-9]+)-day-([0-9]+)\.html$ calendar.php?action=dayview&calendar=$1&year=$2&month=$3&day=$4 [L,QSA]
RewriteRule ^calendar-([0-9]+)-week-(n?[0-9]+)\.html$ calendar.php?action=weekview&calendar=$1&week=$2 [L,QSA]
RewriteRule ^event-([0-9]+)\.html$ calendar.php?action=event&eid=$1 [L,QSA]
<IfModule mod_env.c>
	SetEnv SEO_SUPPORT 1
</IfModule>
If Apache is compiled with built in mod_deflade/GZIP support
then GZIP Javascript, CSS, HTML and XML so they’re sent to
the client faster.
AddOutputFilterByType DEFLATE application/x-javascript text/css text/html text/xml [/code]
Remove „+FollowSymlinks” from the Options directive.
removed it, still getting error.
try to remove everything, only keep
Options -Indexes
and all lines beginning with Rewrite
When this works, you can try to add the line AddOutputFilterByType
Then you can try to add the SetEnv-line, too
Thank you.
I’ll do this suggestion tomorrow and then post the results.
Hope it works ^^.
