Was mache ich hier falsch?
könnte es an den File tags liegen?
auf einem Apache Server funktioniert es, aber nicht auf dem Webspace
Er zeigt mir halt diesen Fehler an:
Internal Server Error
The server encountered an internal error due to .htaccess misconfiguration.
Please check your .htaccess file within this or upper directories for syntax errors.
Diese Anfrage konnte auf Grund eines .htaccess Konfigurationsfehlers nicht bearbeitet werden.
Die Überprüfung auf Syntaxfehler in der .htaccess-Datei in diesem oder einem übergeordneten Ordner ist erforderlich.
[code]AuthType Basic
AuthName "You have to authenticate to access the Member Control page."
AuthUserFile /user/tezcan/www/edit/.htpasswd
for the member and tester actions require any registered user (done, tezcan, tobu.)
<Files ~ “^(|index.php|add_member.php|add_tester.php|del_member.php|del_tester.php|change_leader_country.php|change_leader_gametypes.php|change_leader_image.php|change_member_country.php|change_member_gametypes.php|change_member_image.php|change_member_name.php|change_tester_country.php|change_tester_gametypes.php|change_tester_image.php|change_tester_name.php|move_member_tester.php|move_tester_member.php)$”>
Require Valid-User
for the leader actions require tezcan
<Files ~ “^(add_leader.php|del_leader.php|change_leader_name.php|move_leader_member.php|move_leader_tester.php|move_member_leader.php|move_tester_leader.php)$”>
Require User tezcan
deny everyone from using the include files alone
<Files ~ “^(add_player.php|del_player.php|change_player_country.php|change_player_gametypes.php|change_player_image.php|change_player_name.php|move_player.php)$”>
Deny From All
[/code]
