[code]<?php
// Nuked-KlaN - PHP Portal //
// http://www.nuked-klan.org //
// http://www.nuked-klan.pl - Modif Multilang UTF8 By Doremi //
// This program is free software. you can redistribute it and/or modify //
// it under the terms of the GNU General Public License as published by //
// the Free Software Foundation; either version 2 of the License. //
define (“INDEX_CHECK”, 1);
@include (“conf.inc.php”);
if (!defined(“NK_OPEN”))
echo “
<div style=“text-align: center;”>Sorry, this website is momently closed, Please try again later.”;
exit();
if (!defined(“NK_INSTALLED”))
if (is_file(“install.php”))
header(“location: install.php”);
else
if (is_file(“install.php”) || is_file(“update.php”))
echo “
<div style=“text-align: center;”>Warning ! install.php and update.php must be removed before continuing !”;
exit();
include (“nuked.php”);
$session = session_check();
if ($session == 1) $user = secure();
else $user = array();
$session_admin = admin_check();
$check_ip = banip();
if ($check_ip != “”)
$url_ban = “ban.php?ip_ban=” . $check_ip;
redirect($url_ban, 0);
exit();
if (isset($nuked_nude) && $nuked_nude != “”) $im_file = $nuked_nude;
else if (isset($page) && $page != “”) $im_file = $page;
else $im_file = “index”;
// Securite par phpSecure.info
if (ereg("..", $theme) || ereg("..", $language) || ereg("..", $file) || ereg("..", $im_file) || eregi(“http://”, $file) || eregi(“http://”, $im_file))
die("
<div style=“text-align: center;”>What are you trying to do ?");
$file = trim($file);
$im_file = trim($im_file);
$theme = trim($theme);
$language = trim($language);
// Fin
if ($nuked[‘nk_status’] == “closed” && $user[1] < 9 && $op != “login_screen” && $op != “login_message” && $op != “login”)
include (“themes/” . $theme . “/colors.php”);
translate(“lang/” . $language . “.lang.php”);
echo "<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Strict//EN\" \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd\">\n"
. "<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"pl\">\n"
. "<head><title>" . $nuked['name'] . " | " . $nuked['slogan'] . " |</title>\n"
. "<meta http-equiv=\"Content-Type\" content=\"text/html; charset=utf-8\" />\n"
. "<meta http-equiv=\"content-style-type\" content=\"text/css\" />\n"
. "<link title=\"style\" type=\"text/css\" rel=\"stylesheet\" href=\"themes/" . $theme . "/style.css\" />\n"
. "<body style=\"background: " . $bgcolor2 . ";\"><div><br /><br /><br /><br /><br /><br /><br /><br /></div>\n"
. "<table style=\"margin-left: auto;margin-right: auto;text-align: left;background: " . $bgcolor3 . ";\" cellspacing=\"1\" cellpadding=\"20\">\n"
. "<tr><td style=\"background: " . $bgcolor1 . ";\" align=\"center\"><big><b>" . $nuked['name'] . " - " . $nuked['slogan'] . "</b></big><br /><br />\n"
. _SITECLOSED . "</td></tr></table></body></html>";
else if (($file == “Admin” || $page == “admin” || $nuked_nude == “admin”) && $session_admin == 0)
include (“themes/” . $theme . “/theme.php”);
if (!isset($nuked_nude)) top();
include("modules/Admin/login.php");
footer();
include("Includes/copyleft.php");
else
if ($file != “Admin” && $file != “Stats” && $file != “Members” && $page != “admin” && $nuked_nude != “admin” && $op != “smilies” && $session_admin == 1) setcookie($cookie_admin, “”);
include ("themes/" . $theme . "/colors.php");
include ("themes/" . $theme . "/theme.php");
translate("lang/" . $language . ".lang.php");
if ($nuked['level_analys'] != -1) visits();
if (defined("NK_GZIP") && @extension_loaded('zlib') && !@ini_get('zlib.output_compression') && @phpversion() >= "4.0.4")
ob_start("ob_gzhandler");
top();
echo "<script type=\"text/javascript\" src=\"js/infobulle.js\"></script>\n"
. "<script type=\"text/javascript\">InitBulle('" . $bgcolor2 . "', '" . $bgcolor3 . "', 2);</script>\n"
. "<script type=\"text/javascript\">\n"
. "<!--\n"
. "document.write('<link rel=\"stylesheet\" href=\"css/jquery.thickbox.css\" type=\"text/css\" media=\"screen\" /><link rel=\"stylesheet\" href=\"css/jquery.autocomplete.css\" type=\"text/css\" media=\"screen\" />');\n"
. "-->\n"
. "</script>\n"
. "<script type=\"text/javascript\" src=\"js/jquery.js\"></script>\n"
. "<script type=\"text/javascript\" src=\"js/jquery.thickbox.js\"></script>\n"
. "<script type=\"text/javascript\" src=\"js/jquery.bgiframe.js\"></script>\n"
. "<script type=\"text/javascript\" src=\"js/jquery.dimensions.js\"></script>\n"
. "<script type=\"text/javascript\" src=\"js/jquery.autocomplete.js\"></script>\n";
if ($nuked['nk_status'] == "closed" && $user[1] == 9)
echo "<table style=\"background: " . $bgcolor3 . ";\" width=\"100%\" cellspacing=\"1\" cellpadding=\"8\">\n"
."<tr><td style=\"background: " . $bgcolor2 . ";\" ><big><b>" . _YOURSITEISCLOSED . " :<br /><br/ >" . $nuked['url'] . "/index.php?file=User&op=login_screen</b></big></td></tr></table><br />\n";
if (is_file("modules/" . $file . "/" . $im_file . ".php"))
include("modules/" . $file . "/" . $im_file . ".php");
else
include("modules/404/index.php");
if ($user[5] > 0 && !isset($_COOKIE['popup']) && $file != "User" && $file != "Userbox")
echo "<div id=\"popup_dhtml\" style=\"position:absolute;top:0;left:0;visibility:visible;z-index:10\"></div>\n"
. "<script type=\"text/javascript\" src=\"js/popup.js\"></script>\n"
. "<script type=\"text/javascript\">popup('" . $bgcolor2 . "', '" . $bgcolor3 . "', '" . _NEWMESSAGESTART . " " . $user[5] . " " . _NEWMESSAGEEND . "', '" . _CLOSEWINDOW . "', 'index.php?file=Userbox', 350, 100);</script>\n";
footer();
echo "</body></html>";
mysql_close($db);
?>[/code]
In die index.php soll das rein:
Aber wenn ich es einfüge wird es entweder nicht geladen oder die seite wird garnicht angezeigt.
Kann mir wer bei diesen problem helfen?
MFG
