Hi all,
did you get error message “preg_replace deprecated”?
Solution/workaround:
- find file which produces this error message.
- find “preg_replace” in code
- put a ‘@’ before - example “@preg_replace”
Regards,
climb4fun
Hi all,
Regards,
climb4fun
That just suppresses the message, it does not fix the problem …
“Deprecated” means will be removed in a future version of PHP – so code that still uses something that is deprecated will stop to work once that happens.
And btw., for simply using preg_replace you will not get that message – preg_replace itself is not deprecated at all.
