Java +sql
Hi, I’m working on the project in JAVA and I’ve got a problem with connection to database. My Database (in sql) is located on bplaced.net. This is a fragment of my java’s code:
String url = “jdbc:sql:projektanty.bplaced.net/mysql”;//mysql is a name of my database
String username = “projektanty”;
String password = “******”;
Statement s = null;
Connection c = null;
	try {
		Class.forName("sun.jdbc.odbc.JdbcOdbcDriver");
		} catch (Exception e) {
			System.err.println("Error loading JDBC/ODBC.");
		try {
			c = DriverManager.getConnection (url, username, password);//the problem is with URL, I think...
			s = c.createStatement();
				System.err.println("cannot connect to "+url);
Where’s the problem? Help me, plz.
Try to use ‘localhost’ instead of ‘url’ and make sure that your database-name [quote]String url = “jdbc:sql:projektanty.bplaced.net/mysql”;//mysql is a name of my database[/quote] is the same like your username. Your database can’t be named “mysql” - it is “projektanty” or even start with projektanty.
[quote]Try to use ‘localhost’ instead of ‘url’ [/quote]What do You mean?
My database’s name is of course “projektanty”, soryy for mistake. So now my url is:
url = “jdbc:sql:projektanty.bplaced.net/projektanty”;
But it doesn’t still work:/
URL=localhost
Username=projektanty
password=your pw
But my applet isn’t located on bplaced.net. How would my program know that localhost = bplaced.net ?
You can’t connect your database to external scripts, those functions are disabled to prevent abuse…
Ohh…
I’m writing my program in eclipse sdk. what files should I put on bplaced.net? Where should I put them ? (in what directory?)
Sry, I can’t help you with those programs.
Ok, but if I use WAMP (and now my url = localhost)… do I have to configure anything ? I mean Data Sources (ODBC) in Control Panel or anything else ?
I’m not sure - I only know SQL, php, css, html and some cms’ - but nothing about ODBC or other databse-Systems
thanks for help.
If you use a ODBC-Connection, you can create the Database directly in Windows. But I really don’t know, what to do in JDBC…
Google said: dev.mysql.com/downloads/connector/j/5.1.html
[quote]Google said: dev.mysql.com/downloads/connector/j/5.1.html[/quote]Yeah, I know… but I’ve got a problem… how tu use it?
The documentation can be found here: dev.mysql.com/doc/refman/5.0/en/connector-j.html :astonished:
when I changed part of my code :
try {
System.err.println(“There’s a problem with connection to " + url+”\n"+e);// there’s a change (+e)
There’s a problem with connection to jdbc:odbc://localhost/byczabaza
java.sql.SQLException: [Microsoft][Driver Manager ODBC] Cannot find a name of data source and there’s no default driver.
It can mean that I should configure something in Control Panel… but how to ?
you want to use Microsoft ODBC-Database?
datamystic.com/datapipe/odbc_setup.html
It’s very similar to the control panel in XP. You don’t need to use XAMPP and MySQL then :wink:
If you want to use MySQL, you need something like this:
try {
  c = DriverManager.getConnection ("jdbc:mysql://localhost/byczabaza?user=USER&password=PASSWORD");
    System.out.println("SQLException: " + ex.getMessage());
    System.out.println("SQLState: " + ex.getSQLState());
    System.out.println("VendorError: " + ex.getErrorCode());
moreover you will need to load the JDBC-Objects, like
import java.sql.Connection;
import java.sql.DriverManager;
import java.sql.SQLException;
i think you know, how to add Objects to your Java-Projects. I haven’t done anything with Java before :wink:
