Joomla 1.6 Suche Problem
Hallo beim Aufrufen der Suche unter meiner Joomla 1.6 Installation kommt folgender Fehler:
Warning: Invalid argument supplied for foreach() in /plugins/search/discussions/discussions.php on line 138
Wie kann man den beheben…
[code]<?php
// Check to ensure this file is included in Joomla!
defined(’_JEXEC’) or die( ‘Restricted access’ );
jimport(‘joomla.plugin.plugin’);
  • Search Plugin for Codingfish Discussions
  • @package Joomla
  • @subpackage Discussions
    class plgSearchDiscussions extends JPlugin {
    • Get an array of search areas
    • @return array
      function &onContentSearchAreas() {
      static $areas = array(‘discussions’ => ‘Forum’);
      return $areas;
    • Discussions search. Gets an array of objects, each
    • of which contains the instance variables title, text,
    • href, section, created, and browsernav
    • @param string $text Search string
    • @param string $phrase Matching option, exact|any|all
    • @param string $ordering What to order by, newest|oldest|popular|alpha|category
    • @param array $areas Areas in which to search, null if search all
    • @return array Objects representing foobars
      function onContentSearch($text, $phrase=’’, $ordering=’’, $areas=null) {
      // check we can handle the requested search
      if (is_array($areas) && !in_array(‘discussions’, $areas)) {
      // not one of our areas… leave it alone!
      return array();
      // get the things we will need
      $db =& JFactory::getDBO();
      // build SQL conditions WHERE clause
      $conditions = ‘’;
      switch ($phrase) {
        case 'exact':
        	// build an exact match LIKE condition
        	$text = $db->Quote('%'.$db->getEscaped($text, true).'%', false);
        	$conditions = $db->nameQuote('subject') . " LIKE $text" . " OR " . $db->nameQuote('message') . " LIKE $text";
        	break;
        case 'all':
        case 'any':
        default:
        	// prepare the words individually
        	$wordConditions = array();
        	foreach (preg_split("~\s+~", $text) as $word) {
        		$word = $db->Quote('%'.$db->getEscaped($word, true).'%', false);
        		$wordConditions[] = $db->nameQuote('subject') . " LIKE $word"  . " OR " . $db->nameQuote('message') . " LIKE $word";
        	// determine the glue and put it all together!
        	$glue = ($phrase == 'all') ? ') AND (' : ') OR (';
        	$conditions = '('.implode($glue, $wordConditions).')';
        break;
      // determine ordering
      switch ($ordering) {
        case 'popular':
        	$order = $db->nameQuote('hits') . ' DESC';
        	break;
        case 'alpha':
        case 'category':
        	$order = $db->nameQuote('cat_id') . ' ASC';
        	break;
        case "oldest":
        	$order = $db->nameQuote('created') . ' ASC';
        	break;
        case "newest":
        default:
        	$order = $db->nameQuote('date') . ' DESC';
        	break;
      // complete the query
      $query = ‘SELECT m.thread, m.subject AS title, m.message AS text, m.date AS created,’
      . 'c.name AS section, ’
      . ‘m.thread AS threadid, ‘
      . ‘c.id AS categoryid, ‘
      . ‘c.alias AS categoryalias, ‘
      . "CASE WHEN CHAR_LENGTH(c.alias) THEN CONCAT_WS(’:’, c.id, c.alias) ELSE c.id END as catslug, "
      . "CASE WHEN CHAR_LENGTH(m.alias) THEN CONCAT_WS(’:’, m.thread, m.alias) ELSE m.thread END as slug, “
      . $db->Quote(‘2’) . ’ AS browsernav ‘
      . ’ FROM #__discussions_messages m, #__discussions_categories c’
      . " WHERE ($conditions) AND m.cat_id = c.id”
      . ’ AND m.published = 1’
      . ’ AND c.private = 0’
      . " ORDER BY $order";
      $db->setQuery($query);
      $rows = $db->loadObjectList();
      // get Discussions Itemid
      $sqlitemid = “SELECT id FROM " . $db->nameQuote( ‘#__menu’) . " WHERE link LIKE ‘%com_discussions%’ AND level = ‘1’ AND published = ‘1’”;
      $db->setQuery( $sqlitemid);
      $itemid = $db->loadResult();
      foreach($rows as $key => $row) {
        $rows[$key]->href = JRoute::_('index.php?option=com_discussions&view=thread&catid='.$row->catslug.'&thread='.$row->slug.'&Itemid='.$itemid );
      return $rows;
[/code]
Käsekuchen
