ich wollte fragen ob mir wer helfen kann. Ich bekomme nämlich bei Joomla immer eine Fehlermeldung und ich weiß nicht was ich machen soll.
Die Fehlermeldung lautet:
Hier ist die php datei:
[code]<?php
- @version $Id: html.php 12350 2009-06-24 13:42:16Z ian $
- @package Joomla.Framework
- @subpackage HTML
- @copyright Copyright © 2005 - 2007 Open Source Matters. All rights reserved.
- @license GNU/GPL, see LICENSE.php
- Joomla! is free software. This version may have been modified pursuant
- to the GNU General Public License, and as distributed it includes or
- is derivative of works licensed under the GNU General Public License or
- other free or open source software licenses.
- See COPYRIGHT.php for copyright notices and details.
Utility class for all HTML drawing classes
@static
@subpackage HTML
@since 1.5
class JHTML
* Class loader method
* Additional arguments may be supplied and are passed to the sub-class.
* Additional include paths are also able to be specified for third-party use
* @param string The name of helper method to load, (prefix).(class).function
* prefix and class are optional and can be used to load custom
* html helpers.
function _( $type )
//Initialise variables
$prefix = ‘JHTML’;
$file = ‘’;
$func = $type;// Check to see if we need to load a helper file $parts = explode('.', $type); switch(count($parts)) { case 3 : { $prefix = preg_replace( '#[^A-Z0-9_]#i', '', $parts[0] ); $file = preg_replace( '#[^A-Z0-9_]#i', '', $parts[1] ); $func = preg_replace( '#[^A-Z0-9_]#i', '', $parts[2] ); } break; case 2 : { $file = preg_replace( '#[^A-Z0-9_]#i', '', $parts[0] ); $func = preg_replace( '#[^A-Z0-9_]#i', '', $parts[1] ); } break; } $className = $prefix.ucfirst($file); if (!class_exists( $className )) { jimport('joomla.filesystem.path'); if ($path = JPath::find(JHTML::addIncludePath(), strtolower($file).'.php')) { require_once $path; if (!class_exists( $className )) { JError::raiseWarning( 0, $className.'::' .$func. ' not found in file.' ); return false; } } else { JError::raiseWarning( 0, $prefix.$file . ' not supported. File not found.' ); return false; } } if (is_callable( array( $className, $func ) )) { $args = func_get_args(); array_shift( $args ); return call_user_func_array( array( $className, $func ), $args ); } else { JError::raiseWarning( 0, $className.'::'.$func.' not supported.' ); return false; } } /** * Write a <a></a> element * * @access public * @param string The relative URL to use for the href attribute * @param string The target attribute to use * @param array An associative array of attributes to add * @since 1.5 */ function link($url, $text, $attribs = null) { if (is_array( $attribs )) { $attribs = JArrayHelper::toString( $attribs ); } return '<a href="'.$url.'" '.$attribs.'>'.$text.'</a>'; } /** * Write a <img></amg> element * * @access public * @param string The relative or absoluete URL to use for the src attribute * @param string The target attribute to use * @param array An associative array of attributes to add * @since 1.5 */ function image($url, $alt, $attribs = null) { if (is_array($attribs)) { $attribs = JArrayHelper::toString( $attribs ); } if(strpos($url, 'http') !== 0) { $url = JURI::root(true).'/'.$url; }; return '<img src="'.$url.'" alt="'.$alt.'" '.$attribs.' />'; } /** * Write a <iframe></iframe> element * * @access public * @param string The relative URL to use for the src attribute * @param string The target attribute to use * @param array An associative array of attributes to add * @param string The message to display if the iframe tag is not supported * @since 1.5 */ function iframe( $url, $name, $attribs = null, $noFrames = '' ) { if (is_array( $attribs )) { $attribs = JArrayHelper::toString( $attribs ); } return '<iframe src="'.$url.'" '.$attribs.' name="'.$name.'">'.$noFrames.'</iframe>'; } /** * Write a <script></script> element * * @access public * @param string The name of the script file * * @param string The relative or absolute path of the script file * @param boolean If true, the mootools library will be loaded * @since 1.5 */ function script($filename, $path = 'media/system/js/', $mootools = true) { // Include mootools framework if($mootools) { JHTML::_('behavior.mootools'); } if(strpos($path, 'http') !== 0) { $path = JURI::root(true).'/'.$path; }; $document = &JFactory::getDocument(); $document->addScript( $path.$filename ); return; } /** * Write a <link rel="stylesheet" style="text/css" /> element * * @access public * @param string The relative URL to use for the href attribute * @since 1.5 */ function stylesheet($filename, $path = 'media/system/css/', $attribs = array()) { if(strpos($path, 'http') !== 0) { $path = JURI::root(true).'/'.$path; }; $document = &JFactory::getDocument(); $document->addStylesheet( $path.$filename, 'text/css', null, $attribs ); return; } /** * Returns formated date according to current local and adds time offset * * @access public * @param string date in an US English date format * @param string format optional format for strftime * @returns string formated date * @see strftime * @since 1.5 */ function date($date, $format = null, $offset = NULL) { if ( ! $format ) { $format = JText::_('DATE_FORMAT_LC1'); } if(is_null($offset)) { $config =& JFactory::getConfig(); $offset = $config->getValue('config.offset'); } $instance =& JFactory::getDate($date); $instance->setOffset($offset); return $instance->toFormat($format); } /** * Creates a tooltip with an image as button * * @access public * @param string $tooltip The tip string * @param string $title The title of the tooltip * @param string $image The image for the tip, if no text is provided * @param string $text The text for the tip * @param string $href An URL that will be used to create the link * @param boolean depreciated * @return string * @since 1.5 */ function tooltip($tooltip, $title='', $image='tooltip.png', $text='', $href='', $link=1) { $tooltip = addslashes(htmlspecialchars($tooltip, ENT_QUOTES, 'UTF-8')); $title = addslashes(htmlspecialchars($title, ENT_QUOTES, 'UTF-8')); if ( !$text ) { $image = JURI::root(true).'/includes/js/ThemeOffice/'. $image; $text = '<img src="'. $image .'" border="0" alt="'. JText::_( 'Tooltip' ) .'"/>'; } else { $text = JText::_( $text, true ); } if($title) { $title = $title.'::'; } $style = 'style="text-decoration: none; color: #333;"'; if ( $href ) { $href = JRoute::_( $href ); $style = ''; $tip = '<span class="editlinktip hasTip" title="'.$title.$tooltip.'" '. $style .'><a href="'. $href .'">'. $text .'</a></span>'; } else { $tip = '<span class="editlinktip hasTip" title="'.$title.$tooltip.'" '. $style .'>'. $text .'</span>'; } return $tip; } /** * Displays a calendar control field * * @param string The date value * @param string The name of the text field * @param string The id of the text field * @param string The date format * @param array Additional html attributes */ function calendar($value, $name, $id, $format = '%Y-%m-%d', $attribs = null) { JHTML::_('behavior.calendar'); //load the calendar behavior if (is_array($attribs)) { $attribs = JArrayHelper::toString( $attribs ); } $document =& JFactory::getDocument(); $document->addScriptDeclaration('window.addEvent(\'domready\', function() {Calendar.setup({ inputField : "'.$id.'", // id of the input field ifFormat : "'.$format.'", // format of the input field button : "'.$id.'_img", // trigger for the calendar (button ID) align : "Tl", // alignment (defaults to "Bl") singleClick : true
return '<input type="text" name="'.$name.'" id="'.$id.'" value="'.htmlspecialchars($value, ENT_COMPAT, 'UTF-8').'" '.$attribs.' />'. '<img class="calendar" src="'.JURI::root(true).'/templates/system/images/calendar.png" alt="calendar" id="'.$id.'_img" />'; } /** * Add a directory where JHTML should search for helpers. You may * either pass a string or an array of directories. * * @access public * @param string A path to search. * @return array An array with directory elements * @since 1.5 */ function addIncludePath( $path='' ) { static $paths; if (!isset($paths)) { $paths = array( JPATH_LIBRARIES.DS.'joomla'.DS.'html'.DS.'html' ); } // force path to array settype($path, 'array'); // loop through the path directories foreach ($path as $dir) { if (!empty($dir) && !in_array($dir, $paths)) { array_unshift($paths, JPath::clean( $dir )); } } return $paths; }
}[/code]
Ich hoffe das mir wer helfen kann.
talktothehand
