Almost a week further and still no notice about this…
I find this highly disturbing especially for a site so highly recommended as bplaced.
That no one could even post a small “thank you for telling us” or “we are working on it” that i atleast have some form of confirmation that this actually got through to you people…
But no, i’ve been without any response for 6 days now and it really has hurt my trust in bplaced’ support organisation.
The reason is bplaced still has magic quotes on…
Which means it does the normal and then reverses it due to php 5.3
This is the same as not having magic quotes in php 5.2 and below…
Disable Magic quotes and that will solve the issue… For a support staff member you are not only late but the answer is useless…
Additional information ( Perhaps you understand now ).
implicit_flush Off Off
include_path . .
log_errors Off Off
log_errors_max_len 2048 2048 magic_quotes_gpc On OnMust be turned off…
magic_quotes_runtime Off Off
magic_quotes_sybase Off Off
mail.add_x_header Off Off
true, magic_quotes is still enabled and will not be turned off unless PHP 6.0 at bplaced, this is due to the massive amount of software which still requires that feature.
You may of course disable it, by creating a file named .php.ini - put it in your root-directory or the directory you wish the effect for and insert the following text:
