Das Forum cms „mybb“ bietet einen sehr komfortablen auto updater für plugins und core an(wie bei wordpress). Dieser geht aber leider aufgrund der server einstellungen nicht.
so sieht die versions check php aus:
[code]<?php
// Disallow direct access to this file for security reasons
if(!defined(„IN_MYBB“))
die(„Direct initialization of this file is not allowed.
Please make sure IN_MYBB is defined.“);
$page->add_breadcrumb_item($lang->version_check, „index.php?module=home/version_check“);
$plugins->run_hooks(„admin_home_version_check_begin“);
if(!$mybb->input[‚action‘])
$plugins->run_hooks(„admin_home_version_check_start“);
$page->output_header($lang->version_check);
$sub_tabs['version_check'] = array(
'title' => $lang->version_check,
'link' => "index.php?module=home/version_check",
'description' => $lang->version_check_description
$sub_tabs['download_mybb'] = array(
'title' => $lang->dl_the_latest_mybb,
'link' => "http://mybboard.net/downloads",
'link_target' => '_blank'
$sub_tabs['check_plugins'] = array(
'title' => $lang->check_plugin_versions,
'link' => "index.php?module=config/plugins&action=check",
$page->output_nav_tabs($sub_tabs, 'version_check');
$current_version = rawurlencode($mybb->version_code);
$updated_cache = array(
"last_check" => TIME_NOW
require_once MYBB_ROOT."inc/class_xml.php";
$contents = fetch_remote_file("http://mybboard.net/version_check.php");
if(!$contents)
$page->output_inline_error($lang->error_communication);
$page->output_footer();
exit;
// We do this because there is some weird symbols that show up in the xml file for unknown reasons
$pos = strpos($contents, "<");
if($pos > 1)
$contents = substr($contents, $pos);
$pos = strpos(strrev($contents), ">");
if($pos > 1)
$contents = substr($contents, 0, (-1) * ($pos-1));
$parser = new XMLParser($contents);
$tree = $parser->get_tree();
$latest_code = $tree['mybb']['version_code']['value'];
$latest_version = "<strong>".$tree['mybb']['latest_version']['value']."</strong> (".$latest_code.")";
if($latest_code > $mybb->version_code)
$latest_version = "<span style=\"color: #C00;\">".$latest_version."</span>";
$version_warn = 1;
$updated_cache['latest_version'] = $latest_version;
$updated_cache['latest_version_code'] = $latest_code;
else
$latest_version = "<span style=\"color: green;\">".$latest_version."</span>";
$cache->update("update_check", $updated_cache);
require_once MYBB_ROOT."inc/class_feedparser.php";
$feed_parser = new FeedParser();
$feed_parser->parse_feed("http://www.mybboard.net/latest_news.php");
$table = new Table;
$table->construct_header($lang->your_version);
$table->construct_header($lang->latest_version);
$table->construct_cell("<strong>".$mybb->version."</strong> (".$mybb->version_code.")");
$table->construct_cell($latest_version);
$table->construct_row();
$table->output($lang->version_check);
if($version_warn)
$page->output_error("<p><em>{$lang->error_out_of_date}</em> {$lang->update_forum}</p>");
else
$page->output_success("<p><em>{$lang->success_up_to_date}</em></p>");
if($feed_parser->error == '')
foreach($feed_parser->items as $item)
if($item['date_timestamp'])
$stamp = my_date($mybb->settings['dateformat'], $item['date_timestamp']).", ".my_date($mybb->settings['timeformat'], $item['date_timestamp']);
else
$stamp = '';
if($item['content'])
$content = $item['content'];
else
$content = $item['description'];
$table->construct_cell("<span style=\"font-size: 16px;\"><strong>".$item['title']."</strong></span><br /><br />{$content}<strong><span style=\"float: right;\">{$stamp}</span><br /><br /><a href=\"{$item['link']}\" target=\"_blank\">» {$lang->read_more}</a></strong>");
else
$table->construct_cell("{$lang->error_fetch_news} <!-- error code: {$feed_parser->error} -->");
$table->output($lang->latest_mybb_announcements);
?>[/code]
kann man da was machen oder liegt es gar nicht an den server einstellungen ![]()
danke für die zahlreichen antworten ![]()
