gijsmin
February 9, 2009, 12:48pm
#1
First(english): I use a translator
Question/Frage:
Es ist ein Spiel namens SA-MP und Sie können in MySQL,
aber MySQL bplaced übernimmt keine
I get this:
[23:46:16] MYSQL: Trying To Connect To MySQL…
Connection to MySQL database: Failed !
[23:46:16] Host ‘ip5457c0b2.direct-adsl.nl ’ is not allowed to connect to this MySQL server
[23:46:16] Error in mysql_select_db: MySQL server has gone away
I have this:
MySQLConnect(“.bplaced.net", " ”, “", " ”);
host, User, password, database
How to fix?
chrisb
February 9, 2009, 12:52pm
#2
You can’t connect to the database server from external hosts.
Only your (PHP-) scripts running on the same machine can connect to the database server.
Chris
February 9, 2009, 1:06pm
#4
No you can’t. You can’t connect from external hosts and here you aren’t allowed to install browser games. Sry.
gijsmin
February 9, 2009, 1:11pm
#5
The problem is the host: *******.bplaced.net isn’t a mysql host!!!
In smf is localhost correct
So what’s the mysql host?
Chris
February 9, 2009, 1:12pm
#6
The host is localhost - other connections are disabled.
gijsmin
February 9, 2009, 1:13pm
#7
And if i connect to a other mysql database then it can connect (from a other host)
But this bplaced mysql is a fast one
Please any admin will be enable to let me connect
Chris
February 9, 2009, 1:14pm
#8
That is not possible. The SQL-databases are only for users with a hosted homepage here.
gijsmin
February 9, 2009, 1:16pm
#9
Why ?
Why isn’t the MySQL for external to?
chrisb
February 9, 2009, 1:26pm
#10
Because THAT’S THE WAY IT IS.
Chris
February 9, 2009, 1:33pm
#12
He’s right. External connections are disabled because they’re not allowed.
gijsmin
February 9, 2009, 1:37pm
#13
Can you please give me one reason why not
Chris
February 9, 2009, 1:40pm
#14
Because it’s forbidden and only for users with a hompeage hosted here.
gijsmin
February 9, 2009, 1:59pm
#15
Ok then i go search a other MySQL host (only host ^^)
Everything on the site is good only the MySQL and a onlne ftp system is bad
try this hoster freesql.org/ , when it’s online again…
