Nabend,
ich habe gerade osCommerce installiert und bekomme auf der fertigen Seite nun folgenden fehler
[code]Deprecated: mysql_connect() [function.mysql-connect]: The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in /users/name/www/includes/functions/database.php on line 19
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /users/name/www/includes/functions/database.php:19) in /users/name/www/includes/functions/sessions.php on line 102
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /users/name/www/includes/functions/database.php:19) in /users/name/www/includes/functions/sessions.php on line 102[/code]
nur sagt mir das nicht wirklich etwas… Bei der installation habe ich soweit alles richtig eingegeben (ist jetzt auch nicht so schwer
Ins Admin Tool komme ich auch nicht, dann kommt
Deprecated: mysql_connect() [function.mysql-connect]: The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in /users/name/www/admin/includes/functions/database.php on line 19
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /users/name/www/admin/includes/functions/database.php:19) in /users/name/www/admin/includes/functions/sessions.php on line 102
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /users/name/www/admin/includes/functions/database.php:19) in /users/name/www/admin/includes/functions/sessions.php on line 102
Warning: Cannot modify header information - headers already sent by (output started at /users/name/www/admin/includes/functions/database.php:19) in /users/name/www/admin/includes/functions/general.php on line 34[/code]
kann mir jemand helfen?
beste Grüße
EDIT:
Was ich noch garnicht erwähnt habe ist:
diese anleitung von oscommerce habe ich auch schon probiert, funktioniert allerdings nicht
Warning: require(includes/languages/.php) [function.require]: failed to open stream: No such file or directory in /users/name/www/includes/application_top.php on line 299
Fatal error: require() [function.require]: Failed opening required ‘includes/languages/.php’ (include_path=’.’) in /users/name/www/includes/application_top.php on line 299
Warning: mysqli_real_escape_string() expects parameter 1 to be mysqli, null given in /users/name/www/includes/functions/database.php on line 129
Warning: mysqli_query() expects parameter 1 to be mysqli, null given in /users/name/www/includes/functions/database.php on line 42
Warning: mysqli_errno() expects parameter 1 to be mysqli, null given in /users/name/www/includes/functions/database.php on line 42
Warning: mysqli_error() expects parameter 1 to be mysqli, null given in /users/name/www/includes/functions/database.php on line 42
select count(*) as total from sessions where sesskey = ‘’
[TEP STOP][/code]
