Also das ist der Code des JS:
Script : MultiBox
Version : 1.3.1
Authors : Samuel Birch
Desc : Supports jpg, gif, png, flash, flv, mov, wmv, mp3, html, iframe
Licence : Open Source MIT Licence
var MultiBox = new Class({
getOptions: function(){
return {
initialWidth: 250,
initialHeight: 250,
container: document.body,
useOverlay: false,
contentColor: '#FFF',
showNumbers: true,
showControls: true,
//showThumbnails: false,
//autoPlay: false,
waitDuration: 2000,
descClassName: false,
descMinWidth: 400,
descMaxWidth: 600,
movieWidth: 400,
movieHeight: 300,
offset: {x:0, y:0},
fixedTop: false,
path: 'files/',
onOpen: Class.empty,
onClose: Class.empty,
openFromLink: true,
relativeToWindow: true
initialize: function(className, options){
this.setOptions(this.getOptions(), options);
this.openClosePos = {};
this.timer = 0;
this.contentToLoad = {};
this.index = 0;
this.opened = false;
this.contentObj = {};
this.containerDefaults = {};
if(this.options.useOverlay){
this.overlay = new Overlay({container: this.options.container, onClick:this.close.bind(this)});
this.content = $$('.'+className);
if(this.options.descClassName){
this.descriptions = $$('.'+this.options.descClassName);
this.descriptions.each(function(el){
el.setStyle('display', 'none');
this.container = new Element('div').addClass('MultiBoxContainer').injectInside(this.options.container);
this.iframe = new Element('iframe').setProperties({
'id': 'multiBoxIframe',
'name': 'mulitBoxIframe',
'src': 'javascript:void(0);',
'frameborder': 1,
'scrolling': 'no'
}).setStyles({
'position': 'absolute',
'top': -20,
'left': -20,
'width': '115%',
'height': '115%',
'filter': 'progid:DXImageTransform.Microsoft.Alpha(style=0,opacity=0)',
'opacity': 0
}).injectInside(this.container);
this.box = new Element('div').addClass('MultiBoxContent').injectInside(this.container);
this.closeButton = new Element('div').addClass('MultiBoxClose').injectInside(this.container).addEvent('click', this.close.bind(this));
this.controlsContainer = new Element('div').addClass('MultiBoxControlsContainer').injectInside(this.container);
this.controls = new Element('div').addClass('MultiBoxControls').injectInside(this.controlsContainer);
this.previousButton = new Element('div').addClass('MultiBoxPrevious').injectInside(this.controls).addEvent('click', this.previous.bind(this));
this.nextButton = new Element('div').addClass('MultiBoxNext').injectInside(this.controls).addEvent('click', this.next.bind(this));
this.title = new Element('div').addClass('MultiBoxTitle').injectInside(this.controls);
this.number = new Element('div').addClass('MultiBoxNumber').injectInside(this.controls);
this.description = new Element('div').addClass('MultiBoxDescription').injectInside(this.controls);
if(this.content.length == 1){
this.title.setStyles({
'margin-left': 0
this.description.setStyles({
'margin-left': 0
this.previousButton.setStyle('display', 'none');
this.nextButton.setStyle('display', 'none');
this.number.setStyle('display', 'none');
new Element('div').setStyle('clear', 'both').injectInside(this.controls);
this.content.each(function(el,i){
el.index = i;
el.addEvent('click', function(e){
new Event(e).stop();
this.open(el);
}.bind(this));
if(el.href.indexOf('#') > -1){
el.content = $(el.href.substr(el.href.indexOf('#')+1));
if(el.content){el.content.setStyle('display','none');}
}, this);
this.containerEffects = new Fx.Styles(this.container, {duration: 400, transition: Fx.Transitions.sineInOut});
this.controlEffects = new Fx.Styles(this.controlsContainer, {duration: 300, transition: Fx.Transitions.sineInOut});
this.reset();
setContentType: function(link){
var str = link.href.substr(link.href.lastIndexOf('.')+1).toLowerCase();
var contentOptions = {};
if($chk(link.rel)){
var optArr = link.rel.split(',');
optArr.each(function(el){
var ta = el.split(':');
contentOptions[ta[0]] = ta[1];
if(contentOptions.type != undefined){
str = contentOptions.type;
this.contentObj.url = link.href;
this.contentObj.xH = 0;
if(contentOptions.width){
this.contentObj.width = contentOptions.width;
}else{
this.contentObj.width = this.options.movieWidth;
if(contentOptions.height){
this.contentObj.height = contentOptions.height;
}else{
this.contentObj.height = this.options.movieHeight;
if(contentOptions.panel){
this.panelPosition = contentOptions.panel;
}else{
this.panelPosition = this.options.panel;
switch(str){
case 'jpg':
case 'gif':
case 'png':
this.type = 'image';
break;
case 'swf':
this.type = 'flash';
break;
case 'flv':
this.type = 'flashVideo';
this.contentObj.xH = 70;
break;
case 'mov':
this.type = 'quicktime';
break;
case 'wmv':
this.type = 'windowsMedia';
break;
case 'rv':
case 'rm':
case 'rmvb':
this.type = 'real';
break;
case 'mp3':
this.type = 'flashMp3';
this.contentObj.width = 320;
this.contentObj.height = 70;
break;
case 'element':
this.type = 'htmlelement';
this.elementContent = link.content;
this.elementContent.setStyles({
display: 'block',
opacity: 0
if(this.elementContent.getStyle('width') != 'auto'){
this.contentObj.width = this.elementContent.getStyle('width');
this.contentObj.height = this.elementContent.getSize().size.y;
display: 'none',
opacity: 1
break;
default:
this.type = 'iframe';
if(contentOptions.ajax){
this.type = 'ajax';
break;
reset: function(){
this.container.setStyles({
'opacity': 0,
'display': 'none'
this.controlsContainer.setStyles({
'height': 0
this.removeContent();
this.previousButton.removeClass('MultiBoxButtonDisabled');
this.nextButton.removeClass('MultiBoxButtonDisabled');
getOpenClosePos: function(el){
if (this.options.openFromLink) {
if (el.getFirst()) {
var w = el.getFirst().getCoordinates().width - (this.container.getStyle('border').toInt() * 2);
if (w < 0) {
w = 0
var h = el.getFirst().getCoordinates().height - (this.container.getStyle('border').toInt() * 2);
if (h < 0) {
h = 0
width: w,
height: h,
top: el.getFirst().getCoordinates().top,
left: el.getFirst().getCoordinates().left
else {
var w = el.getCoordinates().width - (this.container.getStyle('border').toInt() * 2);
if (w < 0) {
w = 0
var h = el.getCoordinates().height - (this.container.getStyle('border').toInt() * 2);
if (h < 0) {
h = 0
width: w,
height: h,
top: el.getCoordinates().top,
left: el.getCoordinates().left
}else{
if(this.options.fixedTop){
var top = this.options.fixedTop;
}else{
var top = ((window.getHeight()/2)-(this.options.initialHeight/2)-this.container.getStyle('border').toInt())+this.options.offset.y;
width: this.options.initialWidth,
height: this.options.initialHeight,
top: top,
left: ((window.getWidth()/2)-(this.options.initialWidth/2)-this.container.getStyle('border').toInt())+this.options.offset.x
return this.openClosePos;
open: function(el){
this.options.onOpen();
this.index = this.content.indexOf(el);
this.openId = el.getProperty('id');
if(!this.opened){
this.opened = true;
this.overlay.show();
this.container.setStyles(this.getOpenClosePos(el));
opacity: 0,
display: 'block'
}else{
this.containerEffects.start({
top: top,
left: ((window.getWidth()/2)-(this.options.initialWidth/2)-this.container.getStyle('border').toInt())+this.options.offset.x,
opacity: [0, 1]
this.load(this.index);
}else{
if (this.options.showControls) {
this.hideControls();
this.getOpenClosePos(this.content[this.index]);
this.timer = this.hideContent.bind(this).delay(500);
this.timer = this.load.pass(this.index, this).delay(1100);
getContent: function(index){
this.setContentType(this.content[index]);
var desc = {};
this.descriptions.each(function(el,i){
if(el.hasClass(this.openId)){
desc = el.clone();
},this);
//var title = this.content[index].title;
title: this.content[index].title || ' ',
//desc: $(this.options.descClassName+this.content[index].id).clone(),
desc: desc,
number: index+1
close: function(){
this.overlay.hide();
this.hideContent();
this.containerEffects.stop();
this.zoomOut.bind(this).delay(500);
this.options.onClose();
zoomOut: function(){
width: this.openClosePos.width,
height: this.openClosePos.height,
top: this.openClosePos.top,
left: this.openClosePos.left,
opacity: 0
this.reset.bind(this).delay(500);
load: function(index){
this.box.addClass('MultiBoxLoading');
this.getContent(index);
if(this.type == 'image'){
var xH = this.contentObj.xH;
this.contentObj = new Asset.image(this.content[index].href, {onload: this.resize.bind(this)});
this.contentObj.xH = xH;
/*this.contentObj = new Image();
this.contentObj.onload = this.resize.bind(this);
this.contentObj.src = this.content[index].href;*/
}else{
this.resize();
resize: function(){
if (this.options.fixedTop) {
else {
var top = ((window.getHeight() / 2) - ((Number(this.contentObj.height) + this.contentObj.xH) / 2) - this.container.getStyle('border').toInt() + window.getScrollTop()) + this.options.offset.y;
var left = ((window.getWidth() / 2) - (this.contentObj.width / 2) - this.container.getStyle('border').toInt()) + this.options.offset.x;
if (top < 0) {
top = 0
if (left < 0) {
left = 0
width: this.contentObj.width,
height: Number(this.contentObj.height) + this.contentObj.xH,
top: top,
left: left,
opacity: 1
this.timer = this.showContent.bind(this).delay(500);
showContent: function(){
this.box.removeClass('MultiBoxLoading');
this.contentContainer = new Element('div').setProperties({id: 'MultiBoxContentContainer'}).setStyles({opacity: 0, width: this.contentObj.width+'px', height: (Number(this.contentObj.height)+this.contentObj.xH)+'px'}).injectInside(this.box);
this.contentObj.injectInside(this.contentContainer);
}else if(this.type == 'iframe'){
id: 'iFrame'+new Date().getTime(),
height: this.contentObj.height,
src: this.contentObj.url,
frameborder: 0,
scrolling: 'auto'
}).injectInside(this.contentContainer);
}else if(this.type == 'htmlelement'){
this.elementContent.clone().setStyle('display','block').injectInside(this.contentContainer);
}else if(this.type == 'ajax'){
new Ajax(this.contentObj.url, {
method: 'get',
update: 'MultiBoxContentContainer',
evalScripts: true,
autoCancel: true
}).request();
}else{
var obj = this.createEmbedObject().injectInside(this.contentContainer);
if(this.str != ''){
$('MultiBoxMediaObject').innerHTML = this.str;
this.contentEffects = new Fx.Styles(this.contentContainer, {duration: 500, transition: Fx.Transitions.linear});
this.contentEffects.start({
opacity: 1
this.title.setHTML(this.contentToLoad.title);
this.number.setHTML(this.contentToLoad.number+' von '+this.content.length);
if (this.options.descClassName) {
if (this.description.getFirst()) {
this.description.getFirst().remove();
this.contentToLoad.desc.injectInside(this.description).setStyles({
display: 'block'
//this.removeContent.bind(this).delay(500);
this.timer = this.showControls.bind(this).delay(800);
hideContent: function(){
opacity: 1
removeContent: function(){
if($('MultiBoxMediaObject')){
$('MultiBoxMediaObject').empty();
$('MultiBoxMediaObject').remove();
if($('MultiBoxContentContainer')){
//$('MultiBoxContentContainer').empty();
$('MultiBoxContentContainer').remove();
showControls: function(){
this.clicked = false;
if(this.container.getStyle('height') != 'auto'){
this.containerDefaults.height = this.container.getStyle('height')
this.containerDefaults.backgroundColor = this.options.contentColor;
//'backgroundColor': this.controls.getStyle('backgroundColor'),
'height': 'auto'
if(this.contentToLoad.number == 1){
this.previousButton.addClass('MultiBoxPreviousDisabled');
}else{
this.previousButton.removeClass('MultiBoxPreviousDisabled');
if(this.contentToLoad.number == this.content.length){
this.nextButton.addClass('MultiBoxNextDisabled');
}else{
this.nextButton.removeClass('MultiBoxNextDisabled');
this.controlEffects.start({'height': this.controls.getStyle('height')});
hideControls: function(num){
this.controlEffects.start({'height': 0}).chain(function(){
this.container.setStyles(this.containerDefaults);
}.bind(this));
showThumbnails: function(){
next: function(){
if(this.index < this.content.length-1){
this.index++;
this.openId = this.content[this.index].getProperty('id');
//this.getContent(this.index);
previous: function(){
if(this.index > 0){
this.index--;
this.timer = this.load.pass(this.index, this).delay(1000);
createEmbedObject: function(){
if(this.type == 'flash'){
var url = this.contentObj.url;
var obj = new Element('div').setProperties({id: 'MultiBoxMediaObject'});
this.str = '<object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,28,0" '
this.str += 'width="'+this.contentObj.width+'" ';
this.str += 'height="'+this.contentObj.height+'" ';
this.str += 'title="MultiBoxMedia">';
this.str += '<param name="movie" value="'+url+'" />'
this.str += '<param name="quality" value="high" />';
this.str += '<embed src="'+url+'" ';
this.str += 'quality="high" pluginspage="http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash" type="application/x-shockwave-flash" ';
this.str += 'height="'+this.contentObj.height+'"></embed>';
this.str += '</object>';
if(this.type == 'flashVideo'){
//var url = this.contentObj.url.substring(0, this.contentObj.url.lastIndexOf('.'));
this.str += 'height="'+(Number(this.contentObj.height)+this.contentObj.xH)+'" ';
this.str += '<param name="movie" value="'+this.options.path+'flvplayer.swf" />'
this.str += '<param name="salign" value="TL" />';
this.str += '<param name="scale" value="noScale" />';
this.str += '<param name="FlashVars" value="path='+url+'" />';
this.str += '<embed src="'+this.options.path+'flvplayer.swf" ';
this.str += 'height="'+(Number(this.contentObj.height)+this.contentObj.xH)+'"';
this.str += 'salign="TL" ';
this.str += 'scale="noScale" ';
this.str += 'FlashVars="path='+url+'"';
this.str += '></embed>';
if(this.type == 'flashMp3'){
this.str += '<param name="movie" value="'+this.options.path+'mp3player.swf" />'
this.str += '<embed src="'+this.options.path+'mp3player.swf" ';
this.str += 'height="'+this.contentObj.height+'"';
if(this.type == 'quicktime'){
this.str = '<object type="video/quicktime" classid="clsid:02BF25D5-8C17-4B23-BC80-D3488ABDDC6B" codebase="http://www.apple.com/qtactivex/qtplugin.cab"';
this.str += ' width="'+this.contentObj.width+'" height="'+this.contentObj.height+'">';
this.str += '<param name="src" value="'+this.contentObj.url+'" />';
this.str += '<param name="autoplay" value="true" />';
this.str += '<param name="controller" value="true" />';
this.str += '<param name="enablejavascript" value="true" />';
this.str += '<embed src="'+this.contentObj.url+'" autoplay="true" pluginspage="http://www.apple.com/quicktime/download/" width="'+this.contentObj.width+'" height="'+this.contentObj.height+'"></embed>';
this.str += '<object/>';
if(this.type == 'windowsMedia'){
this.str = '<object type="application/x-oleobject" classid="CLSID:22D6f312-B0F6-11D0-94AB-0080C74C7E95" codebase="http://activex.microsoft.com/activex/controls/mplayer/en/nsmp2inf.cab#Version=6,4,7,1112"';
this.str += '<param name="filename" value="'+this.contentObj.url+'" />';
this.str += '<param name="Showcontrols" value="true" />';
this.str += '<param name="autoStart" value="true" />';
this.str += '<embed type="application/x-mplayer2" src="'+this.contentObj.url+'" Showcontrols="true" autoStart="true" width="'+this.contentObj.width+'" height="'+this.contentObj.height+'"></embed>';
if(this.type == 'real'){
this.str = '<object classid="clsid:CFCDAA03-8BE4-11cf-B84B-0020AFBBCCFA"';
this.str += '<param name="controls" value="ImageWindow" />';
this.str += '<param name="autostart" value="true" />';
this.str += '<embed src="'+this.contentObj.url+'" controls="ImageWindow" autostart="true" width="'+this.contentObj.width+'" height="'+this.contentObj.height+'"></embed>';
return obj;
MultiBox.implement(new Options);
MultiBox.implement(new Events);
und hier ist die seite: http://jmg-times.bplaced.net/v4/bystrice.php
