Whenever i go to componments > PUArcade in the back-end i get a blank page with the following error
The file involved is:
vcard.php
* @version $Id: vcard.php 10381 2008-06-01 03:35:53Z pasamio $
* Modified PHP vCard class v2.0
(cKai Blankenhorn
www.bitfolge.de/en
kaib@bitfolge.de
This program is free software; you can redistribute it and/or
modify it under the terms of the GNU General Public License
as published by the Free Software Foundation; either version 2
of the License, or (at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program; if not, write to the Free Software
Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
function encode($string) {
return escape(quoted_printable_encode($string));
function escape($string) {
return str_replace(';',"\;",$string);
// taken from PHP documentation comments
function quoted_printable_encode($input, $line_max = 76) {
$hex = array('0','1','2','3','4','5','6','7','8','9','A','B','C','D','E','F');
$lines = preg_split("/(?:\r\n|\r|\n)/", $input);
$eol = "\r\n";
$linebreak = '=0D=0A';
$escape = '=';
$output = '';
for ($j=0;$j<count($lines);$j++) {
$line = $lines[$j];
$linlen = strlen($line);
$newline = '';
for($i = 0; $i < $linlen; $i++) {
$c = substr($line, $i, 1);
$dec = ord($c);
if ( ($dec == 32) && ($i == ($linlen - 1)) ) { // convert space at eol only
$c = '=20';
} elseif ( ($dec == 61) || ($dec < 32 ) || ($dec > 126) ) { // always encode "\t", which is *not* required
$h2 = floor($dec/16);
$h1 = floor($dec%16);
$c = $escape.$hex["$h2"] . $hex["$h1"];
if ( (strlen($newline) + strlen($c)) >= $line_max ) { // CRLF is not counted
$output .= $newline.$escape.$eol; // soft line break; " =\r\n" is okay
$newline = " ";
$newline .= $c;
} // end of for
$output .= $newline;
if ($j<count($lines)-1) {
$output .= $linebreak;
return trim($output);
**Below is line74***
**Above is line 74**
class vCard {
var $properties;
var $filename;
function setPhoneNumber($number, $type='') {
// type may be PREF | WORK | HOME | VOICE | FAX | MSG | CELL | PAGER | BBS | CAR | MODEM | ISDN | VIDEO or any senseful combination, e.g. "PREF;WORK;VOICE"
$key = 'TEL';
if ($type!='') {
$key .= ';'. $type;
$key.= ';ENCODING=QUOTED-PRINTABLE';
$this->properties[$key] = quoted_printable_encode($number);
// UNTESTED !!!
function setPhoto($type, $photo) { // $type = "GIF" | "JPEG"
$this->properties["PHOTO;TYPE=$type;ENCODING=BASE64"] = base64_encode($photo);
function setFormattedName($name) {
$this->properties['FN'] = quoted_printable_encode($name);
function setName($family='', $first='', $additional='', $prefix='', $suffix='') {
$this->properties['N'] = "$family;$first;$additional;$prefix;$suffix";
$this->filename = "$first%20$family.vcf";
if ($this->properties['FN']=='') {
$this->setFormattedName(trim("$prefix $first $additional $family $suffix"));
function setBirthday($date) { // $date format is YYYY-MM-DD
$this->properties['BDAY'] = $date;
function setAddress($postoffice='', $extended='', $street='', $city='', $region='', $zip='', $country='', $type='HOME;POSTAL') {
// $type may be DOM | INTL | POSTAL | PARCEL | HOME | WORK or any combination of these: e.g. "WORK;PARCEL;POSTAL"
$key = 'ADR';
if ($type!='') {
$key.= ";$type";
$this->properties[$key] = encode($name).';'.encode($extended).';'.encode($street).';'.encode($city).';'.encode($region).';'.encode($zip).';'.encode($country);
if ($this->properties["LABEL;$type;ENCODING=QUOTED-PRINTABLE"] == '') {
//$this->setLabel($postoffice, $extended, $street, $city, $region, $zip, $country, $type);
function setLabel($postoffice='', $extended='', $street='', $city='', $region='', $zip='', $country='', $type='HOME;POSTAL') {
$label = '';
if ($postoffice!='') {
$label.= $postoffice;
$label.= "\r\n";
if ($extended!='') {
$label.= $extended;
$label.= "\r\n";
if ($street!='') {
$label.= $street;
$label.= "\r\n";
if ($zip!='') {
$label.= $zip .' ';
if ($city!='') {
$label.= $city;
$label.= "\r\n";
if ($region!='') {
$label.= $region;
$label.= "\r\n";
if ($country!='') {
$country.= $country;
$label.= "\r\n";
$this->properties["LABEL;$type;ENCODING=QUOTED-PRINTABLE"] = quoted_printable_encode($label);
function setEmail($address) {
$this->properties['EMAIL;INTERNET'] = $address;
function setNote($note) {
$this->properties['NOTE;ENCODING=QUOTED-PRINTABLE'] = quoted_printable_encode($note);
function setURL($url, $type='') {
// $type may be WORK | HOME
$key = 'URL';
if ($type!='') {
$key.= ";$type";
$this->properties[$key] = $url;
function getVCard() {
$text = 'BEGIN:VCARD';
$text.= "\r\n";
$text.= 'VERSION:2.1';
$text.= "\r\n";
foreach($this->properties as $key => $value) {
$text.= "$key:$value\r\n";
$text.= 'REV:'. date('Y-m-d') .'T'. date('H:i:s') .'Z';
$text.= "\r\n";
$text.= 'MAILER:PHP vCard class by Kai Blankenhorn';
$text.= "\r\n";
$text.= 'END:VCARD';
$text.= "\r\n";
return $text;
function getFileName() {
return $this->filename;
If anyone knows how to fix my problem, would be appreciated.
Thanks in advance
