Hallo!!
Ich habe vor ein Forum für meine Schule zu erstellen, habe auch schon vBulletin 3.6.7 auf den Webspace kopiert. So… Meine Config sieht folgendermaßen aus:
[quote]<?php
|| # vBulletin 3.6.7 PL1
|| # All PHP code in this file is ©2000-2007 Jelsoft Enterprises Ltd. # ||
|| # This file may not be redistributed in whole or significant part. # ||
|| # ---------------- VBULLETIN IS NOT FREE SOFTWARE ---------------- # ||
| ****** NOTE REGARDING THE VARIABLES IN THIS FILE ****** |
| If you get any errors while attempting to connect to |
| MySQL, you will need to email your webhost because we |
| cannot tell you the correct values for the variables |
| in this file. |
// ****** DATABASE TYPE ******
// This is the type of the database server on which your vBulletin database will be located.
// Valid options are mysql and mysqli, for slave support add _slave. Try to use mysqli if you are using PHP 5 and MySQL 4.1+
// for slave options just append _slave to your preferred database type.
$config[‘Database’][‘dbtype’] = ‘mysqli’;
// ****** DATABASE NAME ******
// This is the name of the database where your vBulletin will be located.
// This must be created by your webhost.
$config[‘Database’][‘dbname’] = ‘nfos_vbulletin’;
// ****** TABLE PREFIX ******
// Prefix that your vBulletin tables have in the database.
$config[‘Database’][‘tableprefix’] = ‘’;
// ****** TECHNICAL EMAIL ADDRESS ******
// If any database errors occur, they will be emailed to the address specified here.
// Leave this blank to not send any emails when there is a database error.
$config[‘Database’][‘technicalemail’] = ‘’;
// ****** FORCE EMPTY SQL MODE ******
// New versions of MySQL (4.1+) have introduced some behaviors that are
// incompatible with vBulletin. Setting this value to "true" disables those
// behaviors. You only need to modify this value if vBulletin recommends it.
$config[‘Database’][‘force_sql_mode’] = false;
// ****** MASTER DATABASE SERVER NAME AND PORT ******
// This is the hostname or IP address and port of the database server.
// If you are unsure of what to put here, leave the default values.
$config[‘MasterServer’][‘servername’] = ‘localhost’;
$config[‘MasterServer’][‘port’] = 3306;
// ****** MASTER DATABASE USERNAME & PASSWORD ******
// This is the username and password you use to access MySQL.
// These must be obtained through your webhost.
$config[‘MasterServer’][‘username’] = ‘nfos_vbulletin’;
$config[‘MasterServer’][‘password’] = ‘XXXXXXXXXXXXXXXXXXX’;
// ****** MASTER DATABASE PERSISTENT CONNECTIONS ******
// This option allows you to turn persistent connections to MySQL on or off.
// The difference in performance is negligible for all but the largest boards.
// If you are unsure what this should be, leave it off. (0 = off; 1 = on)
$config[‘MasterServer’][‘usepconnect’] = 0;
// ****** SLAVE DATABASE CONFIGURATION ******
// If you have multiple database backends, this is the information for your slave
// server. If you are not 100% sure you need to fill in this information,
// do not change any of the values here.
$config[‘SlaveServer’][‘servername’] = ‘’;
$config[‘SlaveServer’][‘port’] = 3306;
$config[‘SlaveServer’][‘username’] = ‘’;
$config[‘SlaveServer’][‘password’] = ‘’;
$config[‘SlaveServer’][‘usepconnect’] = 0;
// ****** PATH TO ADMIN & MODERATOR CONTROL PANELS ******
// This setting allows you to change the name of the folders that the admin and
// moderator control panels reside in. You may wish to do this for security purposes.
// Please note that if you change the name of the directory here, you will still need
// to manually change the name of the directory on the server.
$config[‘Misc’][‘admincpdir’] = ‘admincp’;
$config[‘Misc’][‘modcpdir’] = ‘modcp’;
// Prefix that all vBulletin cookies will have
// Keep this short and only use numbers and letters, i.e. 1-9 and a-Z
$config[‘Misc’][‘cookieprefix’] = ‘bb’;
// ******** FULL PATH TO FORUMS DIRECTORY ******
// On a few systems it may be necessary to input the full path to your forums directory
// for vBulletin to function normally. You can ignore this setting unless vBulletin
// tells you to fill this in. Do not include a trailing slash!
// Example Unix:
// $config['Misc']['forumpath'] = '/home/users/public_html/forums';
// Example Win32:
// $config['Misc']['forumpath'] = 'c:\program files\apache group\apache\htdocs\vb3';
$config[‘Misc’][‘forumpath’] = ‘’;
// ****** USERS WITH ADMIN LOG VIEWING PERMISSIONS ******
// The users specified here will be allowed to view the admin log in the control panel.
// Users must be specified by *ID number* here. To obtain a user's ID number,
// view their profile via the control panel. If this is a new installation, leave
// the first user created will have a user ID of 1. Seperate each userid with a comma.
$config[‘SpecialUsers’][‘canviewadminlog’] = ‘1’;
// ****** USERS WITH ADMIN LOG PRUNING PERMISSIONS ******
// The users specified here will be allowed to remove ("prune") entries from the admin
// log. See the above entry for more information on the format.
$config[‘SpecialUsers’][‘canpruneadminlog’] = ‘1’;
// ****** USERS WITH QUERY RUNNING PERMISSIONS ******
// The users specified here will be allowed to run queries from the control panel.
// See the above entries for more information on the format.
// Please note that the ability to run queries is quite powerful. You may wish
// to remove all user IDs from this list for security reasons.
$config[‘SpecialUsers’][‘canrunqueries’] = ‘’;
// ****** UNDELETABLE / UNALTERABLE USERS ******
// The users specified here will not be deletable or alterable from the control panel by any users.
// To specify more than one user, separate userids with commas.
$config[‘SpecialUsers’][‘undeletableusers’] = ‘’;
// ****** SUPER ADMINISTRATORS ******
// The users specified below will have permission to access the administrator permissions
// page, which controls the permissions of other administrators
$config[‘SpecialUsers’][‘superadministrators’] = ‘1’;
// ****** DATASTORE CACHE CONFIGURATION *****
// Here you can configure different methods for caching datastore items.
// vB_Datastore_Filecache - for using a cache file
// $config[‘Datastore’][‘class’] = ‘vB_Datastore_Filecache’;
// vB_Datastore_Memcached - for using a Memcache server
// It is also necessary to specify the hostname or IP address and the port the server is listening on
$config[‘Datastore’][‘class’] = ‘vB_Datastore_Memcached’;
$i = 0;
// First Server
$i++;
$config[‘Misc’][‘memcacheserver’][$i] = ‘127.0.0.1’;
$config[‘Misc’][‘memcacheport’][$i] = 11211;
$config[‘Misc’][‘memcachepersistent’][$i] = true;
$config[‘Misc’][‘memcacheweight’][$i] = 1;
$config[‘Misc’][‘memcachetimeout’][$i] = 1;
$config[‘Misc’][‘memcacheretry_interval’][$i] = 15;
// ****** The following options are only needed in special cases ******
// ****** MySQLI OPTIONS *****
// When using MySQL 4.1+, MySQLi should be used to connect to the database.
// If you need to set the default connection charset because your database
// is using a charset other than latin1, you can set the charset here.
// If you don't set the charset to be the same as your database, you
// may receive collation errors. Ignore this setting unless you
// are sure you need to use it.
// $config[‘Mysqli’][‘charset’] = ‘utf8’;
// Optionally, PHP can be instructed to set connection parameters by reading from the
// file named in 'ini_file'. Please use a full path to the file.
// Example:
// $config['Mysqli']['ini_file'] = 'c:\program files\MySQL\MySQL Server 4.1\my.ini';
$config[‘Mysqli’][‘ini_file’] = ‘’;
// Image Processing Options
// Images that exceed either dimension below will not be resized by vBulletin. If you need to resize larger images, alter these settings.
$config[‘Misc’][‘maxwidth’] = 2592;
$config[‘Misc’][‘maxheight’] = 1944;
|| # Downloaded: 11:02, Thu May 17th 2007
|| # CVS: $RCSfile$ - $Revision: 16258 $
*======================================================================*/[/quote]
Vb_test liefert mir folgendes mit den Daten:
[quote]PHP 5.2.5 Pass
MySQL 5.0.51a-3 Pass
PCRE Pass
magic_quotes_sybase Pass
XML Pass
MySQL Permission Requirements
create Pass
alter Pass
insert Pass
update Pass
select Pass
delete Pass
drop Pass
Recommended Settings (Optional)
GD 2.x Pass
open_basedir Pass
safe_mode Pass
GZIP Pass
magic_quotes_runtime Pass
magic_quotes_gpc Fail
pcre.backtrack_limit Fail
Overall Result: Pass[/quote]
Soweit so schlecht. Wenn ich jetzt auf die datei /install/install.php öffne um zu installieren, kommen endlos viele Fehler… Die ersten 3 Poste ich dann auch mal:
[quote]Warning: fsockopen() has been disabled for security reasons in /users/nfos/www/install/install.php on line 487
Warning: fputs(): supplied argument is not a valid stream resource in /users/nfos/www/install/install.php on line 488
Warning: fputs(): supplied argument is not a valid stream resource in /users/nfos/www/install/install.php on line 489[/quote]
Ich hab auch schon mit Filezilla die Rechte auf 777 gestellt für ALLE Dateien… Ich hoffe mir kann da einer helfen, wenn nötig gebe ich auch die Zugangsdaten weiter. Hab vieles versucht aber will einfach nicht klappen.
Danke schon mal im Vorraus und sorry für den MAGATHREAD…
NFOS
? Also wenn ich jetz in die install.php gehe, ändert sich nichts… Vielleicht muss ich nochmal allen Dateien die Rechte (777) geben?? Könnte ja sein, dass diese beim Ändern zurückggesetzt werden oder?
