akteull scheint es zu gehen, ich sehe ein drupal installation
@ emil: weil es bei bplaced auskommentiert werden muß
ja, weil ich die htaccess datei rausgenommen hatte. jeze wieder rein und das problem ist wieder da…
dann poste die halt mal komplett^^
[code]#
<FilesMatch ".(engine|inc|info|install|make|module|profile|test|po|sh|.*sql|
theme|tpl(.php)?|xtmpl|svn-base)$|^(code-style.pl|Entries.*|Repository|Root|Tag|
Template|all-wcprops|entries|format)$">
Order allow,deny
directory listings for URLs which map to a directory.
Options -Indexes
symbolic links in this directory.
#Options +FollowSymLinks
Make Drupal handle any
404 errors.
ErrorDocument 404 /index.php
for non-existent favicon.ico.
for compatibility with Apache 1.3.
ErrorDocument 404 "The requested file
favicon.ico was not found.
DirectoryIndex
index.php
following cannot be changed at runtime.
php_value magic_quotes_gpc 0
php_value register_globals
0
php_value session.auto_start 0
php_value mbstring.http_input
pass
php_value mbstring.http_output pass
php_value
mbstring.encoding_translation 0
<IfModule
sapi_apache2.c>
php_value
register_globals 0
php_value mbstring.http_input pass
pass
php_value mbstring.encoding_translation 0
and 2.
php_value
register_globals 0
pass
mod_expires to be enabled.
ExpiresActive On
ExpiresDefault
A1209600
<FilesMatch .php$>
# Do not allow PHP scripts to be cached unless
they explicitly send cache
# headers themselves. Otherwise all scripts would
have to overwrite the
# headers set by mod_expires if they want another caching
behavior. This may
# fail if an error occurs early in the bootstrap process, and
it may cause
# problems if a non-Drupal PHP file is installed in a subdirectory.
ExpiresActive Off
<IfModule
mod_rewrite.c>
RewriteEngine on
without the ‘www.’ prefix, you
users to your preferred
ONLY one option:
prefix,
%{HTTP_HOST} ^example.com$ [NC]
[L,R=301]
uncomment and adapt the following:
[NC]
RewriteBase if you are using Drupal in a subdirectory or in a
VirtualDocumentRoot and the rewrite rules are not working properly.
if your site is at http://example.com/drupal uncomment and
line:
Rewrite URLs of the form ‘x’ to the form ‘index.php?q=x’.
RewriteCond
%{REQUEST_FILENAME} !-f
RewriteCond
%{REQUEST_URI} !=/favicon.ico
RewriteRule ^(.*)$ index.php?q=$1 [L,QSA]
[/code]
…also weil das so vom codeabschnitt eher schwer ersichtlich ist:
war ohne # davor, ich habs mal für Dich ausgebessert.
so wie er es gepostet hat sind ne menge Kommentare gar keine… bzw. die beinhalten einen Absatz der net sollte sein.
Danke Dir, dass Du es ausgebessert hast!
MfG
Seiktel
